2008 Chevy 2500HD 6.0 oil change
What weight and brand is everyone running? She only has 40k miles and is ran hwy and city. And has anyone done a spark plug change to a different brand with any noticeable difference?
Ok thank you I wasn't sure. As fir the spark plugs I'm sure they are but was wondering if there was something better out there
Nope. Stick with OEM.
5w-30, your choice of brands. Any name brand oil will do the trick. Synthetic or dino
Based on age, I would warm up the truck, take them out and put some COPPER never seize on them, you will thank me at your 100K interval... I would do the exhaust manifold bolts as well. in fact I would Upgrade them and use Copper never seize, NOW before things become one in there.
Dont ask how I know....
Only ever used AC Delco plugs and 5W-30 (sometimes 10W-30 if 5 not on the shelf) for engine oil. I always have used OEM plugs as I have seen the results of not using them and it never ends good for the engine or plugs.
Same here, stick with OEM. Tons of posts showing they are the best ones to use.
5w-30 synthetic or conventional in any major brand will serve you well.
Stick with AC Delco. The Chevy engines hate Bosch and E3.....
I think all engines hate those gimmick plugs...
I run mobil 1 extended performance 5w-30 in my uncle's '14 sonic and '13 Silverado with the 5.3. In my '02 with the 6.0 I run mobil synthetic high mileage 5w-30 and when I replaced the crappy champion plugs I put in NGK tr5 plugs. I've always had good luck with NGK.
    d.lowrey
    d.lowrey
  • Who's Online   3 Members, 0 Anonymous, 4,187 Guests (See full list)
