What Is The Small Frontal Overlap Test & Why Should I Care?
John Goreham
4/13/2016
Having covered Insurance Institute For Highway Safety (IIHS) crash tests and other safety ratings for many years, I was one of the skeptics who viewed the small frontal overlap test as nothing more than a way for the group to reset its crash tests after every automaker began to get Good Scores across the board on most tests. However, the data IIHS and other groups, such as Volvo, presented started to make me wonder if there was more to the situation. IIHS and others looked at frontal crashes closely and discovered that about a quarter of frontal crashes that involved serious injury or death were of the small frontal overlap type.
The reason that this accident is so serious is the crash only involves 25% of the frontal width of the vehicle. Because the crash misses most of the vehicle's crash structure, the passenger compartment is compromised more than in a moderate front overlap test where 40% of the vehicle strikes the barrier. In addition to causing serious deformation of the body structure and putting the full impact on a small area of the vehicle, the angle results in the vehicle twisting upon impact. In some tests the vehicle rotates a lot. This has an important and deadly effect on vehicles that were not designed for the impact. In many vehicles that scored Good on all tests prior to the new small frontal overlap test being introduced the airbags didn't work properly. In some cases, the dummy's head (or driver's head) would miss the airbag and impact the bottom corner of the left A-Pillar. The forces recorded were in many cases deadly.
So what kind of accident is the small frontal overlap test simulating? Simple. It is a very common type of crash that occurs when a vehicle understeers due to losing grip either from too high of a speed in a corner or from slippery conditions (or both obviously). In my rural New England town, there are no sidewalks on most of the streets and the telephone poles are on the road, not set back. They are literally right on the road meaning the outside edge is on the first inch of the street. It does not take much to screw up and hit one, particularly for a new driver.
I've come around to see IIHS's side of things. The Institute is not a government agency, and I like that. The testing is more rigorous than NHTSA or NCAP's, and I like that too. There is no correlation between a vehicle doing well on this test and costing more than a vehicle that does poorly. However, there is a direct correlation between vehicles that score good on IIHS tests and occupants being safer in accidents. Looking back to the start of the moderate front overlap test, IIHS says "An analysis of 14 years worth of crash data involving IIHS-rated vehicles shows that a driver of a vehicle rated good in the moderate overlap test is 46 percent less likely to die in a frontal crash, compared with a driver of a vehicle rated poor. A driver of a vehicle rated acceptable or marginal is 33 percent less likely to die than a driver of a poorly rated one." The small frontal overlap test is too new for such a comprehensive evaluation, but it would be shocking if it did not have a similar result when time has passed.
Automakers have known since before the current models for sale were designed that this testing was coming. Truck makers knew about this test and some designed to pass it and some did not. The tests are almost never a surprise. Automakers all have their own testing labs and can run the tests themselves. They also are aware of best practices and can design around other's successes. One of the best-scoring automakers of all is Subaru, also one of the smallest in terms of revenue. Subaru's mid-size car scores Good and Audi's scores Poor.
More on this subject here.
Good stuff.
I have always wondered as to why they didn't start testing these years ago. When I had my accident with my 04 HD, the driver's front was hit, mostly in the area the small/moderate overlap tests test for. That cab crumpled in the roof are HARD and the whole left front was obliterated. Sad that safety is only now in the past 5-7 years becoming a bigger deal.
What about the 2500 Crew Cab crash test from iihr
Also not related to this topic but a 2006 Chevy Tahoe driver seat mini Vehicles the power seat has quit working can't find the fuses are relays to fix it started with the heat intermittent I was told by one mechanic it's the modulo please confirm
So if you can't miss it center up on it.
That's my take on this.
Of course this is also done by the insurance companies and they use stuff like this to raise rates so they go out of their way look to exploit weaknesses.
They did this with side impacts then when the manufactures re-enforced they changed to an angled side impact, Then insurance companies started rolling them over.
Thus my 2007 Colorado's insurance jumped up because it failed that one.
Even when GM fixes this the insurance companies will change the tests again . Who knows maybe they will start dropping heavy objects on them next :)
They say it's about safety I say it's all about $$$$$$$$$$$$$
