Yeah I use the remote start as well. But sometimes I forget to blast my AC before shutting off the truck in the morning so it doesn't do much good. Plus it takes a bit for the air to get cold. Where are you in SWFL?
I'm in Bonita Springs and you?
Sweet. I'm in Estero.
Wow...we are really, really close.
Yep! Take me fishing ill tow the boat :D Wouldn't wanna put any stress on that pretty Denali :rolleyes:
No much stress at all for the 6.2. :driving:
Wife's Honda has roll down feature. I roll down from afar and by the time I get to car it helps to cool. :happysad:
Yeah, even with the remote start I still use the fob to roll down the windows in this Texas heat.
There is a fix for that. It can be programmed to work like the previous gen trucks. I like you sometimes forgot but, when I saw they could fix it I got mine done. Now it automatically turns the a/c or heat on based on the outside temp sensor reading. That's if the system is off or on when you get out. I'll look for the #'s you need off the paper work when I get home.
To me the up option is great. Like say you're inside a building or gym and you have the windows down and want to roll them up because it's starting to rain. That's why I wanted it to roll up option, but roll down it okay to let the heat out or what not. I use remote start half of the time so either way it doesn't matter that much to me. I have the option to go up or down on the car and have used it many times for different situations.
I know MVI & Chris White/GTX.... work together for BCM updates, He can update your BCM to allow auto up, not sure if it works for the rear.
Nice, where are they located and can I get a cable to plus in and program it myself? I do my own programming in my car and have coded all kinds of things on it. It would be great to do the same with the truck.
Lol I figured. Well if I see a white Denali in the area I'll be sure to honk! Probably a 1/50 chance it'll be you but whatever! Haha
That's awesome! So if the temperature is 100 degrees (not unlikely this summer) it will automatically put the AC on Auto(full blast) even if I left it on Low? That's cool. Thank you!
I am the same way, they don't sale the cable or their software to allow us to do ourselves already asked this, btw BCM is sensitive. MVI and Chris White are both vendors on here, Chris is under the name GTX or GTP...... I don't remember where Chris White's physical location, I believe around the upper East coast area, maybe the Boston area don't quote me on that.
Edited by camcamaro1991
The repair order from the day I had mine reprogrammed says TSB DOC # 3160050
2014 = power fold mirrors with fob
2015/16 = window roll down with fob. Down only, not up.
I wish I could have the window roll down feature on my '14.
    LonghornMM
    LonghornMM
  • Who's Online   5 Members, 0 Anonymous, 543 Guests (See full list)
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
