If you have a 2017 yes we could retrofit program a 2017 Tahoe/Suburban LTZ cluster to work in that application.
OK awesome
Would it have to be the Tahoe/Yukon cluster or would a Sierra Denali work also? And I am guessing it would have to be the 2017 not a 2016 right?
You want a 2017 Suburban or Tahoe LTZ cluster not Sierra or Yukon as the lighting is wrong for a chevy.
If I am not too concerned about the color of the lighting would the Denali clusters work? Reason I ask is that I can find Denali clusters but the Chevy ones are hard to come by. My truck is the only silverado in the whole country so no one other than me would really know that the color was not correct. Alternatively am I not able to change the color tu suit a Chevy?
No the physical FACE has a different color for the numbers as well as the LED lighting behind it.
I have a 2016 SLT 2500HD Diesel, do I need a cluster out of a denali diesel or will one out of a yukon denali work for me. I realize it has to be a 2016 for a 2016. Thanks for any help!
And would the escalade cluster fit in the sierra?
He said no in an earlier response to someone else that asked.
A yukon denali wouldnt have a Diesel Tach scale.... I mean it would work but might look silly.
That didn't even cross my mind but makes perfect sense. I will try and find a cluster out of a Diesel.
Thanks for the help!
I have a 2015 (not 2015.5) silverado LTZ Z71. Will a 2015 sierra denali gauge cluster work with mine? If so do you know the part number for the gauge cluster.
It won't. I asked the same question in an earlier post.
Edited by j3st3r
Yeah i know the escalade cluster wont work with it but im asking if a 2015 sierra denali cluster will work with a 2015 silverado. I emailed MVI and got there message after i posted here and they said you can switch a 2015 sierra denali cluster into a 2015 silverado.
Sent from my SM-G935T using Tapatalk
Sorry about that. I misread your question.
Chris , I have a 2015 LT Chevy. I had the MVI car play radio conversation. Would I get a cluster from a 2015 since my truck is a 2015 or a cluster from a 2016 since the radio is from a 2016? Thx!
Edited by muddy
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
