ok whos got the quick answer... my 2014 silverado would NEED and can only use a 2014 denali cluster?
Yes 2014 Denali only
Correct. The ONLY exception to this and this is something that needs to be discussed via email as there is a TON of variables at play here would be those of you who have 2014-2015.5 Trucks but have already purchased the MVI CarPlay upgrade.
I'm so sorry, I emailed today. I just noticed the email only on weekends. I'm also very punctual usually but didn't notice this. I have a chance to get a cluster very cheap from a 2014 LTZ for my 2014 WT and wondering if you will do that along will the HMI programming and such for bigger screen.
If you could flag my email and even reply on weekend, I totally respect that and will wait: or I can email then. Just let me know what will work best for you. Thank you sir for the work your doing for us!
So I emailed a dealership asking about the cluster and it's availability , and I was told they are exchange only? You have to buy from a dealership and then they ship the old one back to GM? Does that sound right? Specmo says They are still backordered .
Edited by Txmade
No, thats not correct. At any rate we will have *ONE* 2017 Canadian (or export KPH) spec cluster here shortly if anyone wants it please email us ASAP as we don't think this will last long. Thank you !
Reminder we have ONE 2017 Canadian/Export KPH cluster in stock. We normally DO NOT stock hardware so this is first come first serve at a great price!
Basically, but you need to email GTPrix through his website with your VIN and he will tell you what will work. It's not as cut and dry as you would think.
Will this work in a 2016 sierra SLT I'm in Canada, can you pm me with the price and details please if still available?
If the swap for a SLT to a Denali Cluster, will the functions still stay as the same? As The mileage, lane departure, the park assist, front camera, etc???
Yes our custom programming allows for everything to function as intended as long as it's the correct hardware
    • My brother has a 2007 Avalanche with afm 5.3. It`s got 176,000 miles. Runs like a clock. Never been apart. Co worker has a 2010 Tahoe with afm 5.3. 230,000 miles. Never been apart. Runs like a clock. So, even though cyl deac is a weak spot, they can go the distance.   BUT, these engines had the oil changed regularly, AND had 5w30 as spec. I wonder if they would have lasted this far on 0w20? I`ll bet not.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
    • get a good code reader, and find out what problems the truck has noticed by reading codes. cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    • This is sort of my point, salvage yards aren't overflowing with all these 'poorly' maintained trucks - excellent/good/servicable condition otherwise, salvaged only as a result of a bad engine from poor oil change regiment.    In my area, there are no 2007 to newer gm trucks/suvs in any salvage yards. A few are in the 'recyclers' with very obvious reasons for being there - wrecked.
    • Stabilitrack was a stability control, traction control system, that functioned independently from the transfer case.   Z-71 has nothing to do with the transfer case or differential.   If it does have an AWD system, my memory recalls this being specific to the Denali trim, converting won't be as simple as swapping out mechanical parts like differentials and transfer cases. It will require reprogramming at a minimum. Long story short, not likely worth it.   Pulling a fuse, may disable the AWD system, it might also prevent any other transfer case functions.   However, the AWD case was generally based on the same transfer case you refer to in the 2006 Suburban. If it still has a 4-High and 4-Low where the transfer case locks and splits power 50-50 front to rear, what are you gaining by changing anything? A true-rear wheel drive only, what good will that serve? Not enough to go through the trouble of changing out all the parts.    Generally, all the factory systems will handle a 33" tire and re-gearing. Probably a 35" tire too, if you aren't driving like a caveman. If 35" tires are in the plan...   If you do plan on driving like a caveman or are fully committed to 35" tires, an entire re-think of the build is probably in order. Starting with square one, an IFS front end isn't going to be the best starting point for 35's and caveman driving.
