2 hours ago, GTPprix said:
Bump to make this easier to find for people (Have been directing lots of people here).
I've been trying to find a cluster for my 2018 LTZ Silverado. You have some numbers posted of what may work based by year. Any possibility of any new numbers available to use for the 2018s. If so could you post them, thanks.
GM could always add more to supersede these but these are still the active numbers, I'm not going to keep a running list as any of those would be able to pull up the new part numbers from a supplier.
Ok I am having trouble finding a 2015 Diesel cluster. Anyone have any part numbers?
See page 29 of this thread. All part #s for all years were posted.
Yeah I saw that but those are all for gas trucks not diesels. I was told they are different.
The diesels are different as there's no glow plug circuit in the gas clusters so you'll get a check engine light.  I'd just look for a 2015 Denali diesel on the internet and get the VIN and take it to the dealer to the part #.
Edited by BlkSS
1 hour ago, b-garage said:
Saw this on flea bay today: $125 and free ship.
https://www.ebay.com/itm/2017-Chevy-GMC-Silverado-Instrument-Cluster-84385169/202315996527?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
was going to buy for my 2017, but WAM said it was for 2018......bummer.
Man I'm glad I checked this thread, thank you for posting this, I quickly emailed WAM, his auto reply says they are pretty busy and won't get to emails for a couple days, so I took a chance that it might fit my 2018 and bought it as I didn't want to miss the opportunity. If for some reason it doesn't I'll offer it up for sale. Hopefully it does as I've been wanting to do this for a while. It does say that the lens has some stuffs, I can't tell how bad they actually are. If it's bothersome to me, are the clear lenses replaceable, if so I'll just switch it out with my current one. Thanks again
Edited by Crobinson16
2 hours ago, Crobinson16 said:
Man I feel stupid, I just looked at it and realized it's a diesel cluster. Tack only goes to 5 grand.
My apologies, I should have noted that it was for a diesel.
Post it up for sale on here after you get it. I doubt you will have problem getting your money out of it.
 big rog
10 hours ago, BlkSS said:
@Crobinson16, I may know someone how can take it off your hands.  Shoot me a PM when you get it.
I have submitted a cancel request to the the seller and my order was cancelled. It should be back up for sale soon.
Has anyone added HUD?
Anyone have a compatible cluster for my 2017 SLT 6.2 Gas?
I've emailed WAM (with my vin) for correct cluster PN or if they have one for sale, but no response
Edited by 2009GMC
I've emailed WAM multiple times (with my vin) for correct cluster PN or if they have one for sale, but no response
Because the part numbers are in this thread just like the replies said.
I emailed to confirm a cluster would work before I purchased on eBay. You state that part numbers need to be confirmed before ordering. Yet I never got a conformation.
Have you done many HUDS? My 2018 has the red led hud and that’s it. If I do the Denali cluster swap how much more for HUD and I need which HUD PN?
Not trying to start a pissing match :-)
Edited by 2009GMC
    • If it has a stick I can have fun with it. When my wife first got her Acura years ago I used to tease her about it. I was only interested in muscle cars. They’re gone now. So once a month I drive the Acura. Every once in a while I’ll take it to Redline. But just normal driving on some twisty back roads usually does the trick.
    • I went through again with a test light and everything checked out.    I suppose it could be the MAF itself but I've tried 3 different sensors, 2 of which were in running vehicles previously (the one in this truck, and the one in the donor truck), as well as a new one I picked up from NAPA. I would just be surprised if all 3 were bad.   EDIT/UPDATE: I swapped in the MAP sensor that was originally with the 2010 PCM, that made the code for map sensor voltage high Go away, and the map sensor seems to read normal with key on engine off (14psi or so), but it still doesn't run and does the same thing as before.
    • In addition to a cell or wifi connection, the infotainment needs to be enabled to download software updates. That's a toggle within the system settings.   But...if the truck was prevented from receiving updates in a past life, missing a bunch of updates may mean it won't go back and download all of those because they're not available or the system is too far out of date.   If a formal recall depends on a software update, the recall for that truck remains in an open status until it's applied. The dealer would need to apply the software update in that instance.   Most updates downloaded and applied via the infotainment aren't recalls/safety recalls, they're enhancements and usability fixes which aren't critical.
    • Recently I've been getting a message, "New Brake Pads Detected. Reset Brake Pad Life?", But I haven't had the pads replaced and the truck only has 28,000 miles. The Brake Pad Life shows Front 64% and Rear 79%. I select NO to resetting the brake pad life and the message goes away but comes back at the nest restart.   I stopped by the dealer and was told that it sounds like a software glitch that would require reprogramming. Even though I have the extended warranty, they tell me that reprogramming is not covered unless a module was actually bad and needed to be replaced. Simply reprogramming is not covered. So, they want $200.00 just to diagnose the problem. If it turns out no bad module, another charge on top of that to do the reprogramming. If the cause was an actual bad module, everything would be covered under the warranty.   Just wondering if anyone else has had this problem. Should this issue be covered under the warranty?   Thanks
    • NHT is diesel only, correct.     The GVWRs for NHT on 3/4 ton bring them to the same numbers as many of the 2WD 1 tons.  A crew 4x4 standard 3/4 with NHT is 11,750lbs, a 1 ton same cab/box/4x4 is 12,100lbs.     Hubs and hub bearings are the same for 11.5" and 12" axles.  Housing, diff carrier and ring/pinion are larger for the 12".   All gas use the 11.5" axle, 3/4, 1 ton and 1 ton DRW.
