5 hours ago, Donnation said:
I would love some help.   I don't have any experience taking apart a dash like this.  Can you tell we where to start?  I have pry tools but don't know where to pry first.  Any help you could offer would be greatly appreciated.  Thank you so much.
Do you have the truck or suv?
No there are no 2015 blue gauges... you can use the part number list.. in this post LOL
Thought since it was the suv...
Chris, im litterally 2 mins away from shipping my cluster to you. I have my order number on the box. Should i send signiture required? It will be insured too.
Nope you’re good :)
Ok. Also no info in box...  forgot and i sealed it. Its on its way!!!!! Just need the vin which is attached with my order....
And its off to you.  Will be there on wednesday. Thank you!!!
Edited by RACERX7775
Have a question about our 2014. I looked at all of the GM part #'s referenced to work for the 14- Early 15... and can not find a single cluster... plenty of 15.5 and up clusters on the web.
So looking at the chart... the 2015.5 and up clusters will not work period? Thanks!
Dont worry, if none around right now, there will be soon.  Everyday, there is another one that gets stolen or wrecked.. Unfortunately....
I would caution relying on only online posts/listings only.  If you haven't reached out to dealers, or other businesses like Specmo, Pace Performance, etc that sell clusters, I would do so.  As Chris already posted previously that some say "New" but aren't and have some sort of damage.  If you really want to upgrade, contact WAMS from their website about upgrading to Apple Car Play/Android Auto to get 2016 to work in your 2014.
Edited by BlkSS
Here is what Chris posted earlier today in order to eliminate questions and give people direction.  Please READ.
Yes, this is what I was referencing earlier.... I ran all of these #s... not one to be found on ebay ect lol.
I posted that for anyone who may find this thread before finding Chris's.  I noted "Please READ" so hopefully people will use that thread for pertinent questions instead of muddying it up with useless comments or questions that would be answered by READING.
On my previous post where I quoted you @AlljackedupZ71, that is why I suggested directly contacting dealers or other businesses like Specmo, Pace Performance, etc INSTEAD of relying on ebay, etc.  Also why I mentioned to contact WAMS from their website to see what all you need to make a 2016 cluster fit in your 2014.
Also, Specmo offers cheap 1-day shipping as I have purchased from them before and was very happy.  I've also used the dealership and ebay for a cluster as well but recommend Specmo.  I did call Pace and they were comparable to Specmo but Specmo was new versus refurbished from Pace and Specmo was still slightly cheaper, even after the 1-day shipping.
Edited by BlkSS
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
