19 minutes ago, CRApex said:
HUD isn’t available on Sierra Denali, any year.  Are you saying you can have it programmed then purchase the additional components, modify the dash etc..to make it work?
In short, YUP. Read through this thread and search here. There is someone who did it. But they had to fabricate the top visor to get it to fit.  It was a big undertaking, and alot of custom work. But it can be done.
Also, the cluster has to be programmed anyway BEFORE its plugged into my truck. So its just a slight added cost to program it for HUD to work. But its also not cheap to source all the parts for the HUD system.
Edited by RACERX7775
Add more content.
Not all vehicles require custom mods...
i was able to purchase all the correct parts and install them
(2105 suburban)
Edited by migizi
(2105 suburban)
Exactly. Your 2105 Suburban, can come with factory HUD, So the parts are direct bolt-on for the most part. So, ALL pickups HAVE to be modded to make HUD work because NO pickups come with HUD from the factory. Also, there are no visor or dash parts for factory install.
I think i've said it here but it bears repeating: There is about a 90% chance if you buy a cluster on ebay marked as New its in fact used. I'm getting units that are VERY obviously physically used in (before we even verify programming on them) that people are being sold as new; FYI.
Chris,
Are you going to be replying to emails this Thursday/Friday?  I've stumbled across this mode over the holidays and am wanting to verify what part number I need to source for my truck.
Thank you,
2 minutes ago, RWaddell said:
Chris,
Thank you,
Page 29 here i think.   What truck do you have?
I have a 2016 2500HD Chevrolet Duramax.  I am wanting to do the LTZ cluster out of a Tahoe/Suburban so that it has matching colors.  I have seen the comments about the tach and I'm ok with that so long as the tach actually still displays the correct RPM.
I have read through all the pages and believe i have the correct process down I just need to verify with Chris the correct part number and want to know if he would be back to business as normal this week for me to email in via his website.
Edited by RWaddell
Per our email from the 28th there is nothing green for a 2016 diesel.
Sorry, I have checked my inbox and junk box but never saw a reply.  Thought I had seen in this thread that the Tahoe/Suburban model that was released in the 2016 vehicles could be programmed to work and just have the Tach be 6k so that's not the case?
Is there anyway you could email me again so that I could try to coordinate the correct Denali cluster that i will need to source?
Thank you,
Edited by RWaddell
I thought i could only get the red Denali cluster for my 14 LTZ. A little late now, but oh well. I never even knew the blue was available for my 14.
It’s not for stock trucks. That’s covered in this thread.
Hmm. I have to admit, i read a ton of pages in here but that was a topic i didnt see about.
It’s in the post on page 29 that we direct everyone to for part numbers :)
Yeah thats where i got the part number. I went back and figured id start at like 35.... and damn, at pg 36, i saw the mod using the cruize cluster for the blue lighting.
On 1/3/2017 at 9:38 AM, GTPprix said:
Get a 2016 Tahoe LTZ cluster it'll have the chevy lighting and you just wont use the whole 6K Tach, probably the best way to handle it.
Did this option turn out to not work on the diesel trucks?  This answer was in response to 'Jakewake23" asking about getting a cluster for his 2016 diesel on page 8.
And thank you again Chris for your time.  If this needs to be moved off the thread please let me know.
    RyGuy43
    RyGuy43
  • Who's Online   2 Members, 0 Anonymous, 522 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
