4 minutes ago, SS502 said:
This is when you get in range...
This doesn’t show up. I don’t see this at all.  I just check my email, and I did let Chris know I had rear park assist. Hmm...I guess I’m taking it out?
@GTPprix  I know you let me know you’ll help me out Monday, but should I remove the new cluster and put my old one back in today?   Thanks Chris. Much appreciated for any help.
Edited by Jchoi
I would wait, I have the full suite of sensors, maybe it’s different for just the rear parking? All I get on the 8inch screen it the camera view and grid for turning/lining up on a trailer.
I used to get just the pat display with the rear symbols projected. It’s too bad..,was so excited. I’m sure Chris will help figure this out. Ty SS502
I’m sure you’re bummed if it’s truly not working properly...I would be too. But as far as I recall there have been no failures on these conversions. Even if it is not working right, try and be positive and he will make it right if it’s not.
[mention=130449]GTPprix[/mention]  I know you let me know you’ll help me out Monday, but should I remove the new cluster and put my old one back in today?   Thanks Chris. Much appreciated for any help.
That was directed at racerx but same situation contact us Monday from the website and we can run through some tests first. 9 times out of 10 it’s something silly like park assist is turned off or something like that lol
I have faith It will get worked out.  I’ll email you during your stated hours on Monday. The parking assist seems to work, (red triangle on radio screen), but nothing on the cluster display.  I was hoping it would work just like before. Thanks and looking forward to talking then.
Out of curiosity, anyone else with an LT plus and an upgraded cluster experience something
@SS502 what display option is that?
Edited by Jchoi
[mention=195397]SS502[/mention] what display option is that?
My Denali Cluster will be here tomorrow, I have an LT with the LT 2 package(I think that’s right). I have the rear park sensors but not the front! Not sure if I can help in looking at things for you once I get mine but I’d be glad to help out!
That would be great as we have basically the same setup. Please let me know.
Edited by Jchoi
I’ll let you know when I get it all installed and what I find out! Shoot me a PM with anything as you want me to Check out in it!
Thanks so much. The main things is whether the cluster displays the rear sensors. I’ve tried everything. Even in the radio settings. The cluster acknowledges turning off the rear sensors, but it does not respond when I activate them from radio settings. It’s probably pretty straight forward that I have to send it back to Chris.
I hope it can get figured out pretty quickly! After reading the thread, I hope mine works. I didn’t specify that I had the rear sensors when I placed my order. I wasn’t aware that I had to! This process in upgrading the cluster is way different then it is when I did this on my 2017 F150 last year!
I agree, but I’m hopeful that it will be remedied soon. Everything I’ve seen shows that Chris and WAMS stand by their product, and hell, it might vpeven be operator error. I’ll keep you updated.  The display is beautiful though.  You’ll enjoy it.
Edited by Jchoi
It’s the Technology view.
    • You need a better code reader/scanner.  You are missing codes.  Did the dealer give you a copy of the SAVI scan from that visit?     If the fluid hasn't been changed, change it.  Shudder will likely go away.
    • TLDR to my other post...   Hard. Pass.  Too many what ifs.     Are you set on a 3.0 Duramax?  Have you considered anything not GM just in case?  If you don't have to have a pickup, lots of other options for $27,000 out there.
    • I see some red flags.   - No mention in the Carfax if the oil pump belt was changed.  LM2s had a 150,000mi service interval, and its got 164,245mi on it.  So right out the gate it needs about $3000-3500 for that to be done before driving it another 150,000mi.  Belt is at the rear of the engine.     - If something happens to the transmission valve body, the special coverage is expired by mileage.  That will likely be an out of pocket expense, with zero or near zero GM participation if something happened even though its in by time.   - 2020 LM2s seem to need timing chains after 80,000mi at some point.  They fixed this end of 2020/starting 2021 model year engines.  They will usually set a P0016 I think?  There is another $8000-10,000 if it needs a chain.  The main chain is at the back, secondary at the front so the pump belt would be done at the same time if it needed chains.     - Long oil change intervals.  7,000-8,000mi on average, probably close to 0% or perhaps to or beyond 0% on the OLM.  Lots of them not at the dealer which makes me wonder how much of the oil ran through that truck was the proper Dexos D rated 0w20 oil and not just gas engine 0w20, which is not the same at all.     - Long fuel filter changes, again likely taking the fuel filter life to 0% or more.  First one went 28,603, second was done 43,094 miles later at 71,697, from there another 46,452mi to 118,149mi, and then the most recent one 37,026mi later at 155,175mi.  So counting its original fuel filter, its had only 4 fuel filters on it.  No bueno IMO.         Good news?    - It has had only two warranty trips to the dealer.  The first free service (end of December 2020 on the Carfax), and the transmission reprogram recall (end of August 2025 on the Carfax).     - Truck did a LOT of moving, so that might explain the lack of emissions related repairs like bad NOX sensors, bad exhaust temp sensors, bad glow plugs, etc.         The "emissions system checked" could just be how something was flagged for Carfax.  GM dealers have to do SAVI reports for warranty repair orders so they scan the truck.  So its possible that is there for that?
    • Thank you, @Z45!   NOTE - No all repair shop/Dealers reports to Carfax   That is my main concern.  The CARFAX looks way too clean for a 6 year old anything with 164,245 miles.  Even something known for reliability (like many Toyotas) typically has a lot more replaced, like a Nav screen, interior trim, shock/strut, or brake pads.  And surely the last set of tires (installed at ~58k miles) would be bald unless those were all highway miles.   I'm tempted to pay a local dealer to look up the VIN, but am not sure if that will be worthwhile.  Last time I did this, it was 100% useless, and I felt scammed - they noted the bumper was replaced years ago and that's it.  A 5-year old could spot the accident damage, even though nothing was on the CARFAX.   After giving the dealer a call, the truck may have a hard shift, but they have to verify with their mechanic if that's even a concern.  And I've test driven about a dozen of these now, many near Chicago, and half the trucks shift hard/odd at all throttle positions.  The ones with aftermarket lifts/larger tires shift terrible, and 3 stock trucks shifted so violently I thought the transmission valve body was going out.   At this point I'm conflicted, as I need a vehicle, and am coming up short locally.  Northern trucks in this price range tend to have either multiple owners, a lot of mods (lifts/oversized tires without re-gearing), and are generally in rougher shape.   If this truck showed up in your neighborhood for $27k and you had to purchase it sight-unseen, with the possibility of needing a 10L80 rebuild, torque converter, or rear end - would you do it?  I'm convinced most of the 10L80 trucks I test drove are broken, they can't all shift so bad, with massive flares/slipping/lurching and mis-matched downshifts like a teen driver learning stick.
    • From the spy shots, the front end does look like it's borrowing some styling cues from the Canyon. I'm more interested in the powertrain news than the screens though. If the 3.0 diesel survives into the next generation, that alone will keep a lot of current owners interested.
