19 minutes ago, Boewing1 said:
Need some help....
Did the cluster swap all went good I thought. But and there always a big but. Parking assist is not showing up in the cluster. I think all else works. The seat does vibrate. White auto and media did the programming. Any help would be awesome.
Was hoping to make an official post after there was a confirmed fix however very long story short there is a bug that seems to have been introduced into the late 2017 Firmware that carried into the branch used for the 2018-2019 units as well. Basically The clusters ignore ANY configuration for a rear park assist only even though they are configured as such; the bug even allows for the display of the park assist on/off state messages but not the actual sensor data.
This would never have been an issue for GM as they never built any trucks that used these clusters in that time frame that DIDN'T have UD5 (Front and Rear Park Assist). I have spent a metric ton of time recently benching up a mockup to test this and indeed was able to see no matter what data frames were sent (or emulated) from a park assist unit the clusters would not display anything for rear park assist. Jchoi is testing a third revision of a work around that hopefully should work as we were able to display park assist information on his unit on the bench, I was even able to replicate this situation in my own 2018 Denali.
Hopefully will have something to report here very soon, it should be noted since the discovery of this we have stopped taking any orders for 2018 trucks that have rear park assist only but again hope to reverse that the second we have good feedback.
Edited by GTPprix
I commend your effort and follow through with me on this. I will let you know ASAP via the website once it’s installed.
Thanks man and I appreciate your patience helping me try to make sure we cover all of the bases here; this certainly is a weird one as a regression to omit features is not something GM would pay a supplier for so its got to be a bug at this point lol
Hopefully if I purchase something else from you, it will be more routine haha.
Yeah this is definitely not the norm I promise hahaha
So, is it safe to send my cluster back to you now for this workaround?  You don't need the park assist module too then, right?  My truck is a 2017 and I believe I was the first one to experience this issue.  You and I traded emails for several days but life got busy and I never send it back to you.  Ready now if you are!
No. There is no tested proven solution currently but if one becomes available it will be posted here immediately.
  • Thanks 1
10-4.  Fingers crossed it functions properly in Jchoi's truck, so hopefully you'll be closer to a guaranteed fix.
Edited by lapoolboy
@GTPprix sent you an email
Edited by Jchoi
So the small number of you experiencing this issue owe @Jchoi a big thank you :) We were able to confirm the work around to the GM bug does indeed work on the 2018 units (and likely the 2019 units) to my knowledge only one person with a late 2017 has this bug but I'm hoping it should work as well. Contact us from the site to schedule a patch application :)
Edited by GTPprix
  • Thanks 1
Well, while I might have had patience with the situation, the real effort was on Chris’s part to keep trying without compromise. Do not hesitate to do business with WAMS and Chris. He spent way more time than I’m sure he expected and finished what he promised. Here’s a snapshot of the final product
@GTPprix
E-mail sent.  Anxious to finally get this working!  Thanks to you and @Jchoi for your efforts on this!
Weird that the vehicle icon is an SUV though?  ?
Edited by lapoolboy
11 hours ago, lapoolboy said:
@GTPprix
Not weird, normal ;) If you want the Chevrolet startup logo etc (e.g. you have a Silverado) it will have the SUV icon as its all tied together.
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
    • I really did not measure what came out. I carefully followed directions to check level after i did the spill and fill and filter change. I used 10 quarts. 9 was not quite enough. My trans temp was about 175 when I checked it. Truck sitting in my driveway very close to level where I always check oil pretty much every time for consistency. My driveway is just ever so slightly downhill to run water to the street.
