1.5" Bora HC Wheel spacer
Meethead
Hey everyone,
I ordered some BORA Hub Centric 1.5" wheel spacers for my truck for a rubbing issue on the UCA at full turn. Does anyone use BORA spacer? any feedback or pics of the stance!?
I had Bora spacers on for a few months, they are a great product. I had no issues at all.
Pics should be in my build thread.
Thank man! After scrolling through 10 pages on your build thread, I saw them.
Sorry, :), didn't think it was that deep.
I ran Bora Spacers on my 9-7x Aero as well. No complaints at all from me.
  • 5 months later...
Did you have to trim the factory studs in order to make the 1.5 inch spacers work?
I'm thinking I boo boo'd. Now got the 2" set for my rear to push the rear tires out like the front after my lift.
from my understanding the 2 inch spacers clear no problem,however the 1.5 or the 1.75 I'm unsure of.
Not with the factory wheels. Also, I didn't have to trim the studs when I was using a 1.25".
  • 3 months later...
Can you post some pics of yours with the 1.25 or 1.5? Wanting to do that t my 16 with stock GMC AT wheels
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 641 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
