I like it! :)
-S
Thanks bud, I forgot to buy zip tie mounts so I could put on the gutter guard I picked up to do behind the grille so hopefully I get that done some time this month.
Picked up a 10 pack of heavy duty, metal body LED's for $8. Tapped the dome light for interior. And for just under $50 I picked up the wiring harness for the bed lights and tapped it with some 8" COB LED's for the bed. gallery_167032_4679_161196.jpggallery_167032_4679_104630.jpg
  • Like 4
I’m going to need a link to those LEDs. I’m looking to do footwell lights as well.
Installed wireless charger in the console lid on my jump seat. Got the Choetech charger off amazon for $12.99 shipped. Install was very easy. Biggest concern was whether or not the charger would work through the rubber mat and the black plastic of the lid. Only way you can know the charger is there is looking in the console and seeing the usb cable connected. Might hardwire to cig lighter plug some day
Lightbar was $25 from amazon. The wiring and switches and inline fuse, did not cost more than $40.
Looks good. How difficult was it to mount in that location?
It was not bad at all. The hardest part was getting the nut on the back side of the aluminum to get the bar on due to a bolt on the truck being sort of in the way. I just had to put the bolt to the aluminum and screw the bolt on rather than push the bolt through first which is seen below. 9a048e2e5aba18f00141f481ff0c4dc6.jpg
Thanks for the pics I think I may try this when I get home.
When State budgets get tight again I think we will see cops writing tickets for those lights. Not DOT approved. Around here there are people getting silly with those lights....matter of when the cops get orders to bust em for State revenue.
Yup, these cops know how to spot a non-DOT light at 65+MPH.  If anything, they'll write you up for not having a cover on them, except for behind the grill.
Was debating between adding the extra red top battery I have or storage.  Figured the extra storage was cheaper and easier.
I originally made this video on how to install wireless charging in the console.
I want to add some type of magnets to hold the phone in place i have noticed that some time if i stop suddenly or go down a long hill the phone will slide forward any one have any suggestions on how to get some supper powerful magnets that i can put in the rubber pad or some other idea. i would love to hear any suggestions.
https://youtu.be/-MNLWAk9bqA
Edited by chrisfg
I imagine magnets would be a bad idea, considering it's an inductive charger. Might mess with data storage on the phone too, not sure.
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,246 Guests (See full list)
