It was not bad at all. The hardest part was getting the nut on the back side of the aluminum to get the bar on due to a bolt on the truck being sort of in the way. I just had to put the bolt to the aluminum and screw the bolt on rather than push the bolt through first which is seen below. 9a048e2e5aba18f00141f481ff0c4dc6.jpg
Do law enforcement give you a hard time when you running the lights @ night?
Or does it depends on your state or county laws etc..? I live in Tennessee.
Sent from my SM-J727V using Tapatalk
On 11/15/2017 at 9:38 PM, bndawgs said:
Was debating between adding the extra red top battery I have or storage.  Figured the extra storage was cheaper and easier.
have a part number?
If i did that I’d probably spend more on the plexiglass than the actual light bar[emoji23] it was only $25 but I do like the idea for a more expensive light bar
Lol maybe I'll try it and post some pics. I still have my lower air valance so I'll be cutting a hole in that.
Sent from my Pixel XL using Tapatalk
I bought this LED kit for $13.99, it had enough modules to do the interior and the bed. I'm very impressed with the quality for the cost of these modules.
The modules are UL listed, waterproof and pre-wired. The kit came with a harness, additional wire, real 3M adhesive pads, and screws if you chose to hard mount the modules.
The light is 5000k, and looks to me just slightly yellow to the factory interior lights although that might just be the surface its shining on, its very close.
I used 1 module at each seat and put the remaining 8 modules in the bed in addition to the factory bed lights. The bed has areas under the rail where the steel is stamped at an angle that made a perfect spot to mount these lights.
  • Like 6
On 10/18/2016 at 3:50 PM, mattpest said:
Personally, I didn't like the Philips. The light was whiter, but not brighter since there are no LED pieces on the distal tip in the bulb. I ordered the JDM white LED lights and love them for reverse lights. I can see so much farther and behind and around the sides backing up. I HIGHLY RECOMMEND USING THE JDM BULBS!! For bed lighting, I ended up just using the Phillips bulbs since I already bought them and didn't want to piss the money away. I don't use that overhead lamp much, so the Phillips work well enough. The Phillips license plates lights look good too.
Question for you do you have a backup camera?  Because I put those on my 17 ltz and backup camera image is blurry any recommendations  any buddy with backup camera and reverse led lights
More information please...
Sorry I hid the link in "LED kit" was that the more information you were looking for?
Did that fit without any modification ? Good Christmas idea!
On 1/12/2017 at 8:56 AM, Ravenkeeper said:
For about $50 and/or less, I have completed or am going to K.O. in next few weeks.....
1) Removed my AM/FM antenna whip and will be installing "hidden antennas," when they come in. Cleaner look and I don't really listen to AM or FM, but will need them for my scanner.
2) Front Tow Hitch - found a hitch for $50 and will be installing it, hopefully, in the near future.
3) Mounted my CB antenna on the front right stake hole (about $40 invested in parts for my previous truck & $80 for the handheld router, that was not needed).
4) Tow hitch brake light - modified it to only light up when the brakes are applied. $20 for the light assy & couple of hours of research to cut the correct wire.
5) Bed lighting (#7) - Spent about $30 so far, including S/H, and looking to spend another $5 for j-box connector today/tomorrow. Should have all parts by next weekend.
6) Magnetic Phone holder (#5) - completed this one before Thanksgiving, $20.
Other mods for less than $50-ish that I'm looking at doing....
1) Window tint across top 4-5" of windshield, down even with the lane departure camera housing. Should cost less than $30.
2) #1 front/back
3) #3
4) #10&11
5) MAYBE #15
I did the led for the reverse light and no luck with the back up camera image did you have the same problem
Sorry. I just saw this, but i have yet to have an issue with them. I don't drive with them on all the time. Normally my back roads in town and i always turn them off when a car comes. I live in CT but have used them in Vermont and soon upstate New York which was why i put them on to begin with. The back roads up where i go snowmobiling do not have street lights and last time i drove up there i hit a deer after reaching the top of a hill. But the cops in my town dont even go after my grill lights either. Multiple kids have them in my town and i have them on my car too. Could just be luck. Not sure. But soon i will be buying a DOT one so i can argue the ticket better.
I did have to trim off a piece on the side and the bolt underneath.  Only took about 5 mins to do.   The only thing I don't particularly like is that the cross brace prevents the lid from opening all the way.  So to avoid that, I don't have the back lid snapped in.  Still stays put though.   I put a qt of oil, some tire plugs, some gloves and a couple rags in there for now.  will probably try to put in a small socket set and a couple odd tools.
    whenindoubtuseahammer
  • Who's Online   3 Members, 0 Anonymous, 427 Guests (See full list)
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
