18 hours ago, SS502 said:
Looks factory to be honest...does it block off the turn signal?
Look's Good
On 3/30/2018 at 12:19 PM, Marv88 said:
Re upholstered jump seat in leather. You can get the kit leftovers from trucks that didn't need them due to having a full console at local upholstery shops or on eBay for less than $50 bucks.
Got any link?
Got any link?
I just bought mine from a member here a week or 2 ago. They show up on Ebay from time to time as well. Last I checked there was only a cocoa and dune colored set on Ebay, you just have to keep an eye out for the black if that's what you need/want.
Sent from my SAMSUNG-SM-G890A using Tapatalk
On 7/14/2018 at 9:57 PM, Deadpoollane said:
Are your turn signals tinted?
3 hours ago, H-town Silver Bullet said:
You looking for jumpseat?
I have mine in garage but without internal wiring.
Im in Houston
I'm looking for a leather skin, is yours a complete jump seat?
39 minutes ago, H-town Silver Bullet said:
Its cloth.
But complete minus wiring
I've got a cloth jumpseat already but it's greyish but I wanna make it black
Thanks though
CF8A4873-D42E-4E66-B166-5AE7B82DC224.thumb.jpeg.d5d9c89098b1528b4f145add5040d20e.jpeg41162B01-2A24-41B1-8AF2-1E700558DC8C.thumb.jpeg.8fe06addff13fccb41a8ac3a3f840650.jpeg4878A11F-DE21-4B95-9C48-27F40361A772.thumb.jpeg.acd79b6281bfa7e199516cb863cfc361.jpeg41690D0A-0AEF-4EA1-B941-7899D586FAA0.thumb.jpeg.de0826ecc270d6a327b459c11b38b91c.jpeg
Swapped out the drivers A-Pillar cover for a Driver's Assist Handle, last Sunday.  $52 for the part thru Amazon Prime, and about 30 minutes total to remove the original cover and install the handle.  The close up of the upper end, was cause some of the guys were complaining that it didn't lineup.  Once I got the leash from the original cover tucked away, it mated up flush.
Edited by Ravenkeeper
  • Like 4
Swapped out the drivers A-frame cover for a Driver's Assist Handle, last Sunday.  $52 for the part thru Amazon Prime, and about 30 minutes total to remove the original cover and install the handle.  The close up of the upper end, was cause some of the guys were complaining that it didn't lineup.  Once I got the leash from the original cover tucked away, it mated up flush.
That’s one of my few dislikes with my ‘15, had no clue they were out there. Got a link by any chance?
Google 23285090 for the gray one...
https://www.thepartstruck.com/oem-parts/gm-interior-assist-handle-23285090?c=Zz1pbnRlcmlvciZzPWRvb3ImbD0yJm49U2VhcmNoIFJlc3VsdHMmYT1jaGV2cm9sZXQmbz1zaWx2ZXJhZG8tMTUwMCZ5PTIwMTcmdD1sdCZlPTUtM2wtdjgtZ2Fz
As it happens I was planning on ordering this. Cheaper than amazon, albeit no prime shipping. Came out to $47 total I think with shipping? **make sure your color is correct**
I used Amazon, to save me a 80 mile round trip.  Most definitely make sure that it’s 23285090.  Worth the $52 I spent, far less than the cost of the item, and two round trips to the dealership (one to order and the other to pick it up).
https://www.amazon.com/Genuine-GM-Molding-Pkg-Part/dp/B00TA7UUM2?keywords=23285090&qid=1547714442&sr=8-1&ref=sr_1_1
It that an Air Bag I see ?.....is the new trim compatible with the Air Bag (if that is what I'm seeing ?)
    Chris80s
    Chris80s
  • Who's Online   4 Members, 1 Anonymous, 688 Guests (See full list)
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
