8 hours ago, Thejet07 said:
Why do I have to stumble upon threads like this? More money spent
Some are FREE!!  Some day, I'm going to re-read through all of these, and make a list, starring (*) the ones that I have done and highlighting the ones I'm planning on.
  • Like 4
3 hours ago, SS502 said:
Well...I picked up a new right side handle (part number 22923598) off eBay for $20.69 with free shipping so I will swap out the cap without the key hole when it gets here. I had a eBay coupon so I used it and got a pretty good deal, now I will have a spare handle should I ever need one :thumbs:
Pseudo-keyless entry?
Nice mod.
  • Thanks 1
Nice mod.
Well sort of I guess lol, I did it so the lock cylinder is not ripe for the popping. As long as my fob and truck battery are good I will never need the key. I thought of this when I read another members thread about his truck getting broken into. I figure this MIGHT just persuade some stupid thief to move along to an easier target. Even if I get locked out, I will just drill through the end cap and use my key but for now I’m just hoping it works as a deterrent.
Here is the thread that better explains it:
Edited by SS502
I haven’t read through the whole thing but I will. I’m a sucker
Yeah, I'm a sucker for a "good read" too.
Tried out the “freakin genius” mod. Unfortunately, I heard no difference except the rattle was gone. Oh well. Guess I’ll just have to buy a muffler for a deeper tone. Thanks for the tip though
I see your $300+ illuminated bowtie and raise you a $10 backlit grill...
I raise you a $5 backlight grill [emoji6]
  • Haha 1
3 hours ago, Neallynein said:
I’ll call...
  • Like 4
Stakes are getting high guys... :D  What LEDs did you use though, inquiring minds would like to know?
Stakes are getting high guys... [emoji3]  What LEDs did you use though, inquiring minds would like to know?
[emoji23] I bought one of the cheap 5m wheels of led on amazon. I used like 1.5-2 feet of the strand for the grill I believe
I was thinking of doing that in the bed. Never did it before. Can I just tap into the bed lights or do I need a fuse? Again, I’m a noob
1 hour ago, SS502 said:
I’ll call...
...ALL IN
and that's only about 2% of the collection and are just a few of my single emmiter jobs, keeping the big guns under raps....  I got more stockpiled lithium and silicon than most small countries.
Same as the guy above I'm sure, I used 50/50 60led/M that come on the 5m spools for a couple bucks.  I used a full 5m for my grill and wheel well lights of the 5000k white strips.  For the wheel wells I got the already waterproofed led strips then put them in some waterproof sleeves then pumped the sleeve full of clear epoxy, since they are exposed to so much more abuse that most other places.  For the grill lights I just used the waterproof LED then epoxied over them to hold them in place.   To get good results you are going to need to learn to solder.
You can just tap into the existing bed lights they are already fused/protected.
  • Like 4
    whenindoubtuseahammer
  • Who's Online   0 Members, 0 Anonymous, 283 Guests (See full list)
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
