Does that just slide right over?
Yes. Uses a clamp and bolt to secure. Some have used a tack weld to be a little more "secure" from theft.
Link?
This was an eBay purchase where he threw out a low bid an won the item.
Edited by pgamboa
@pgamboa is right on both counts.
The tip just slides over the existing pipe and clamps on. All you need for the install is a deep 15mm socket.
Link?
Click here
I was pretty shocked I didn't get outbid.
Edited by RHStansbury
What's your name on eBay? Next time let me know when you are bidding on something, I'll counter your bid so you won't be shocked next time... LOL
  • Like 6
Finally decided on a way to mount my phone. I used an old suction cup mount and cut it down to size.
I wanted to do something with this spot.
Here is before I got started
Here is about half way through cutting down the base.
Here is the finished product for mounting. I cut it down to where is fits very snugly in the slot. It's very sturdy. I will prolly cut it a little further and plasti dip the base as it squeaks ever so slightly over speed bumps and such.
0981d77d3038a5b78f6f4425a0c3efee.jpg0c43b651d32a016a369f301ffa3ba8c5.jpga07e1a105cd0449fb3f7b711a9edc2d5.jpg3f0246725d5a951ebabe910fc26f260b.jpgf49207d1c283d35f02046c8c78b8644b.jpg
Then I started thinking about my apple car play feature. I really like using the maps on the head unit. So I graves my 10 foot cord and started mocking up how to accomplish getting it to the USB. Here is what I came up with.
I noticed this hole in the back of the storage slot. I test fit the end of my cable and it fit.
Next was to find out if I could access this hole. So I popped off the fuse panel.
I grabbed a flat head screw driver an put the end in the hole and to my great surprise was able to locate it. This is the best pic I could get. I tried to get the shiniest part to show.
I then snaked the end up to the hole. This was way easier than I thought it was going to be.
Then I fed it through to the floor board.
I fed it over the OBD2 connector
Then fed it over these screws that attach the lower dash to the upper until I was in the passenger side floor board.
Surprisingly I was able to hit the last screw and come up the under side of the glove box. It fits perfect and does not pinch on bit.
Yet amazingly again it fit perfectly to the top storage door. I looped it around the top hinge and over to the USB. This fit so well I couldn't believe it.
This is how much I left sticking out of the slot. I made sure to test this before I started feeding the cord. Once the mount is in it is just enough cord to plug into the phone and not protrude in the way.
And the finished product with cord. It tucks so nicely into the mount until you need it. I love how it turned out.
So about $22 for the cord and $20 for the mount.
  • Like 5
Nicely done. FYI - You can remove the USB connector from the glove box and plug your cable in from behind.
$15 bucks at Auto Zone. I couldn't take stuff sliding into the foot wells. 2f8d9a7ee13f2c9372308fcd22ad6958.jpg
I've been looking for something like this
2 days driving with it, has not budged. I have nothing heavy in it either.
do you still have the tag laying around? It's a 20 minute drive to autozone, if you have it I can just order it.
I ripped off the side label but I believe I left the UPC code and I also have the receipt. I tried to scan the UPC code and search for it on amazon, but not the exact one came up
Can of plastidip, some masking tape, and an hour ! Blacked out emblem.
Can be done but doesn't always last. I'd highly recommend the plastidip. When I did my bow ties I had a few people ask if they were the factory black ones. $20 can versus $100+ bow ties... and it was easier to do.
I'm looking at PlastiDipping my bowties, and still debating on doing my rims. Will I only need to clean the surfaces that I want to "dip" or do I need to rough it up?
Waymon, where did you get your phone holder? How did you get it to stay in the pocket?
Spent a grand total of $4.82 on a cargo management system for the bed.
What process did you use to install yours? I'm looking at doing two of these, definitely one, at 2x12.
    Afennell19
    Afennell19
  • Who's Online   5 Members, 0 Anonymous, 785 Guests (See full list)
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
