HA, I haven't washed mine since October. Dealership washes it for free each time I get my oil changed (Nov & last week), they do a decent job. Grabbing new headlight bulbs later this morning, watched one die about halfway to work tonight, and some LED exteriors.
Slow day at work? I may repaint all three of mine (2", 2-5/16" & Pintle). Why did you choose red?
Any recommendations on paint that won't flake off after a few months?
Ratcheting Cargo bar with Divider bar. Best money I have ever spent. Keeps buckets of baseballs and coolers from flipping over and sliding.
Photos?
Don't have a pic of mine but this is the set up. I have a roll up cover on mine so I put my bar close to the tail gate with the divider bar almost touching it so it's pinned between the bar and the tail gate for easy access.
0E0E1415-D06A-4AAF-991E-164F900DCA99_zps
Edited by jimbaeumel
  • Like 5
I went with red to tie in with the red of the Z71 emblems I added one6ccf000673da78d5095b3e7a88fc6ee1.jpg to the tailgate as well. Also makes you look at it before you hit your knee on it lol
I completely forgot about that bar! I had one years ago, and thought that it was a great idea. I may have to look for another.
I have the hitchmate like in the picture and it works great, but you may want to look at the one Reese makes. Its a little lighter and seems like it may be easier to move when needed. Saw one in person after I bought mine and experienced a litte buyers remorse. They are just one of those things that you dont realize you need it until you have it.
I took the cheap route. 2x6 that I already had. I cut it to 64.5 inches. It's plenty tight, but I didn't want it coming out. Those slots are pretty shallow. I wouldn't take more than a quarter inch off, maybe 3/8 inch, I wouldn't think.
Picked up a couple totes I saw in home depot. Was hoping I could fit two across, but I could only get one in there. But it fits great in between the board and tailgate. It fits just right enough that it doesn't slide around.
Sent from my XT1254 using Tapatalk
  • Like 3
I know that feeling ALL TOO WELL, some of the trucks at work have pintle hooks, met a couple of them while working graveyard shift. Don't think that if they were red that the "meetings" would have been any different.
For about $50 and/or less, I have completed or am going to K.O. in next few weeks.....
1) Removed my AM/FM antenna whip and will be installing "hidden antennas," when they come in. Cleaner look and I don't really listen to AM or FM, but will need them for my scanner.
2) Front Tow Hitch - found a hitch for $50 and will be installing it, hopefully, in the near future.
3) Mounted my CB antenna on the front right stake hole (about $40 invested in parts for my previous truck & $80 for the handheld router, that was not needed).
4) Tow hitch brake light - modified it to only light up when the brakes are applied. $20 for the light assy & couple of hours of research to cut the correct wire.
5) Bed lighting (#7) - Spent about $30 so far, including S/H, and looking to spend another $5 for j-box connector today/tomorrow. Should have all parts by next weekend.
6) Magnetic Phone holder (#5) - completed this one before Thanksgiving, $20.
Other mods for less than $50-ish that I'm looking at doing....
1) Window tint across top 4-5" of windshield, down even with the lane departure camera housing. Should cost less than $30.
2) front/back black bow ties
3) Philips LED reverse lights
4) K&N airfilter & cabin filter
5) frame plugs
So Friday I picked up a couple 1N4004 diodes for some light mods ($2), a 2"x12"x8' for bed divider ($11), two rattle cans of PlastiDip for the 2"x12", my front/back bowties & front "Z," 12ga cable terminal ends to relocate my AM/FM antenna under the hood ($5). Some of these were originally not listed in my list about a month ago. Should be completing these in the next few days and will post pictures soon.
Painted hitch again. Did it at work with their paint. On the clock. [emoji1303]523c741f2f2e3eb432a2b75cb6ec54f7.jpg
looks nice, but you wont get many people to bust their shins on that.
Do you put Loctite or anti-seize on the nut?
