Finally got the step bar lights added. $6.00 for lights and $3.00 for a package of T taps. Already had some extra wire on hand. The lights are sold as a pair so I only used one per side. Pretty impressive little lights.
attachicon.gifIMG_20170414_191053473_zpsynpgztq3.jpgattachicon.gifIMG_20170414_195029460_zpsmpzg36fp.jpgattachicon.gifIMG_20170414_195219271_zps2fbf9iep.jpgattachicon.gifIMG_20170414_202030635_zpsbozyrg7r.jpg
Very cool. What did you tap into? Any chance you have links to the items you used?
Looks awesome!!! How do you turn the lights on? and yes how did you wire them in?
Lights were from ebay http://www.ebay.com/...=STRK:MEBIDX:IT, there are some cheaper, but this is a US seller. Tapped into the dome light wire under the dash using a T tap.
b30c79bf3b546fedf9ed73a5ae5cd096.jpg I added side clearance lights on mine!! Built all the brackets out of aluminum and also have strobes for our funeral home as well!!
  • Like 5
Did the AM/FM antenna relocation. So happy with the results and lead on the black plug that fits perfectly
What size is the plug for this mod? I need to pick one up.
I wish it was as easy as the NBS trucks. Bolt antennae down the inside of the fender and use the escalade cowl piece that didn't have the antennae. So clean looking.
Looks great
3/4", got mine at Lowe's, 2-pack, for a couple dollars.
Anyone know where to get a short antenna that has equal or possibly better reception than the long ugly stock one?
Or just use one of the round ones in the side of the bed ...
Found some strip LED lights at my local dirt Cheap. Basically what you can get from auto zone. Paid $7 for the strip $3 for a pack of quick connectors. I even stepped it up and spent another $4 on some good wire. Lol
How did you wire these up?
^what he said. Hillman company. They're located in the the hardware isle in the those blue pull-out drawers. 3/4 diameter is dead nuts a perfect fit but they don't exactly snap in place due to the way the trim piece is constructed. They come in 2-packs though so I pushed the first one in place and will see if just a "friction fit" holds it in place; especially at highway speeds. If it doesn't. I'll run a small bead of glue around the second one and try it again.....
I did my antenna mod about a year ago, didn't use glue, it's still in place. Most of my driving is highway, to/from work, and I always park into the wind. We get 30MPH+ winds, regularly, around here. Last week, the winds are over 60MPH. The winds are headwinds on my way home.
Just search the forums for under dash lighting. Very easy mod.
There's a grey wire on driver side a pillar you can tap into for them to go on with dome lights or you can go into Ignition power like I did for them to always be on when key is turned.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
    • Just wanted to get a idea of how many of you still have problems with your radio cutting out during the first few minutes of driving, my 2024 GMC Sierra still does this after a little over 2 years of complaining to my dealer about it, and OTA updates no longer complete, the check for updates in settings is greyed out for the second time while trying to install a update, my dealer took about a week to play around with it the first time this happened, and somehow got the check for updates to work, even though it would always show system is up to date when I knew it wasn't, now again 1 month later its greyed out again when the OTA update N25-F163BU tried to install, which ironically is the update to help with reliability of future updates.
