One of the best Threads ever! Have any of you guys done anything with the aux. battery tray?
didn't someone put a storage box on the battery tray?
There is! I have been wanting to do this myself but I got a air compressor as a gift so I'll most likely stick that wheee the extra battery tray is.
http://www.gm-trucks.com/forums/topic/193216-diy-engine-bay-storage/?fromsearch=1
Edited by Alexantics
Some has, there is a write up in this thread or one of the "What have you done...today" threads.
Alexantics quoted the link just above your post to the write-up.
  • 4 weeks later...
For me wireless charging and garage door opener remote in the console the best 2 affordable modifications i think you can do under $50. I like the Plasi Dipe bowties so that is a must.
here are some of the links to the how to that i used.
i have not been here in a while and now i have some inspiration for new modifications on my truck that won't break the bank. thanks to all that contribute to this posting.
Edited by chrisfg
Just some random stuff I did for under $50
wrapped logo
Superman Sierra
Plasti dip dash
Decal
Painted skid plate
Color matched grill trim
Vinyl
Plasti dip/ didn't keep
Painted hood latch slot
Fuel door vinyl wrap
Slow acceleration fix
Finally had the chance to sit down and post.
I originally deleted (removed/capped) my AM/FM antenna about a month of so after I had bought my truck. Yesterday, I had to go to ACE Hardware and get new supplies to "relocate" my AM/FM antenna. I grabbed some hardware Saturday on my way home from work, the bolt (1/4-28) worked but the nut, that fit the bolt, did not work. Grabbed "7mm fine thread bolt and nut, and new eyelets for the cable. My son came out to see what I was doing. Had him grab the antenna post/stud (while holding the antenna up over his head), and the radio started picking up the station that it was set to, he had that "how in the world" look on his face. :freak: Took the cable with both new eyelets on it and touched the post, kind of picked up the station, then touched the end of the antenna to the cable, had connectivity and clear signal, so I attached the one eyelet with the bolt, still great signal. Placed the antenna under the fender, zip-tied it, routed the cable out of the way of the hinge, placed the eyelet on the post, went to grab the nut off the front cover, and MURPHY decided to show up, down under the cowl, behind the headlight and never made it to the ground. :devil: Searched for that stupid thing for a little short of a hour, figured it got caught somewhere, so I drove around the block (rough road), looked in the truck and walked around the block, still nothing. :devil::banghead: So, today, after work, while I'm out looking for a new microwave (to make "the boss" happy), I'll have to go get another 7mm fine thread nut ($0.25). The good thing is, I can install it without opening the hood and right there in the parking lot. :fingersx:
I've seen others complain about it, but had never experienced it, until last week. But mine almost feels like the tranny is slipping slamming into 2nd gear.
What size block did you use? Got other photos, so we can see what you did and where?
I used about 1/2 inch block, others use paint sticks, if you have adjustable pedal this might not won't work
Edited by SuperSierra
I used about 1/2 inch block, others use paint sticks, if you have adjustable pedal this won't work
I am work right now and can't see the video you posted, but you can do the mod w/ adjustable pedals.
Edited by OldBlue61
Yes it does. I have adjustable pedals and did the same mod.
You should take pictures, a lot of people with adjustable pedals say it doesn't.
If you made a step by step it would help a lot of people out.
I like this guys step by step. I reference it a lot because it's so well written
Sorry, I am mechanically versed but computer illiterate! All I can do is walk you through to make it easy peasy!
1st go to ACE Hardware and buy the White nylon/plastic Spacers "6QTY TOTAL" in this EXACT SIZE....1/8" thick and 1.125" OD the 1.250" would work too but not sure.
2nd I would use a plastic/synthetic shim instead of wood but I suppose wood works fine too...I am just that way though. Home depot sells a package of em couple bucks.
3rd go home and remove the plastic retainer clip on the electrical connection to accelerator the bigger one and disconnect......Look straight up and disconnect the smaller connection there is no safety clip on that one.
4th get a Torx drive probably 30-40 in size not sure I never looked just thought to myself it was bigger than I expected and remove the 2qty Torx bolts that attach the actual pedal to unit.
5th use a 10mm extended socket on a 6" extension and remove the 3qty nut/washer all in ones that hold the unit onto the plastic bracket. The nut inside the unit can only be reached through a hole and JUST BE CAREFUL WHEN REMOVING YOU DON't DROP the nut inside the unit.....I DID but got it with magnet just was annoying and 105 degrees out....
6th once the sending unit has been removed place your 2qty plastic SPACERS PER BOLT=6QTY TOTAL from ACE over the bolts that have a I.D that is just bigger that the bolt itself...I think the ID's were .300"
7th Place unit back onto bolts and even it out inside it's preformed position and slowly tighten up the nut/washer all in ones using a TORQUE PATTERN because it flexes and creaks and keeps getting tighter to the plastic form this way and the washers seat etc. You will know when your done because the bolts will now stick past the nut/washer just shy of 1/4" and they will be snug but can deceive you if your not careful when tightening.
8th put the accelerator pedal back, tighten the 2qty bolts nice and tight and place BOTH electrical connections back!
9th now pull the carpet and foam back/down and out of your way. CUT the 1st Inch of plastic SHIM and last 2" off so your left with the middle....Grab a prybar or cats paw or something and some decent caulk! Just shoot a bunch of caulk up under the gap behind the plastic piece that is sticking 1/8"1/4' off the metal floorboard/firewall and use your pry bar higher up on the side and pull it away more and quickly jam the shim in behind and let go with pry bar.....Still not done grab a flathead and push the shim up yet higher to really get that bugger up in there tight! Replace foam carpet etc. and you don't need to cut any of that if your wondering.
10th final step promptly back the pig out of driveway and rip it! It's freaking NICE all thanks to the OP!
Can you stack 3qty per bolt? Yeah, you probably could but I wanted to make sure I had enough bolt left and didn't want protruding awkwardly from plastic mold on the floorboard. I perfectly fine with the 2qty stacked and the finished product is very stout nothing janky/chincy about it!
Not true. Many of us have done this with adjustable pedals and noticed a big improvement. No special step-by-step needed, it's the same as the regular pedals ...
Edited by sk
I don't have adjustable pedals on my truck so evidently I don't know what would or wouldn't work other then what I have read.
So if my information on the topic is wrong you can blame it on my referrals, one being you...
    • Thanks, all. It sounds like keeping the software "as is" is the best course of action.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
