WOW even the 2016-17 oem HID/LED headlights are rated poor/marginal
By adjusting the headlight housing. I stole this pic off the interwebz but see the holes thru the upper shroud behind both headlights? If you look down thru them there is a phillips head screw that these give access to. I believe turning counter clockwise raises the beam. Dont go to much though or you will blind drivers going the opposite way. I am going to raise mine just a hair more and make sure I have them level with one another and be done. The low beams are giving me much better down road distance and I have not been flashed a single time for to bright of lights.
How much did you turn the adjuster screw? I want to do mine but not sure how much to adjust.
  • Replies 71
incorrect, unless the LED housing adjusters are different.
the adjusters are between the shroud and airbox (white plastic, facing up and allen head) clearly visible on drivers side from spare battery box
mine work great, slightly adjusted cut-off up
You sir are correct! Realized it when I tinkered with mine a little more last weekend but couldnt remember my password to get on and correct it on my ipad....
My guess would be a 2-3 turns in all counter clock wise.
every truck can be different
mine required 1/2 turn more one side to equalize, but only 1/2 turn both sides from there to get cut-off correct
Man, i feel like my headlights have done well. Better than my Ram. I think my 2016 Sierra's HID headlights are better than nt Silverado's LED's. Albeit not looking quite as cool.
Lights in my '16 Silverado Z seem fine to me.
As are mine, in fact the projector lights work better than the halogens on my former Avalanche. Seems like a half-a$$ed review anyway. Indicates that Sierra/Silverado projectors were "acceptable" but what the heck does that mean when they also indicate that headlights were down rated for excessive glare to oncoming drivers? Too much light causing the glare, or too white, color of test road, ambient lighting, etc.? Nowhere did I see any impartial evidence relative to light output, distance, color temperature, angles of light projected, or methodology to quantify "glare".
Critics can chuckle all they like, but I tested my Silverado at night on unlit country roads against my trade-in Avalanche before purchase and the improvement of the Silvy's projectors over the halogens was dramatic on low beams. Silvy's 2 high beams were at least as good but not better considering the Avy had 4 halogens on high.
here is my thought on these new headlights for my 16 1500 LT
by far the best i ever owned even driving down county roads, etc, and they are on par with my grandma's 2010 cad dts. mine might be a touch brighter due to age.
drove my cuz's brand new 16 ford f150 without the led option. and honestly i felt like i was blind.
also i noticed that turning the gauge display down to lowest level will help out greatly. or at least it does for me when driving down dark roads.
They have a larger opening on the sierra. The thin on on the Silverado causes the beam to be cut down on the edges. The projector still uses the reflective surface in the light lens as well. It's not completely like a projector... The size of the light housing IE the entire assembly not jus the projector is the difference.
Agreed, the Z71's blackout housing surrounding the projector lens cuts down on the side lighting, BUT the vertical housing on the LED fogs is not only larger than the Sierras but its the silvered vertical mounting directs the majority of the lighting towards the side of the vehicle whereas the Sierra's horizontal mount directs the majority of it forward. Bottom line is that when running a Silverado with both the lows and fogs, the composite light pattern is about the same as the Sierras running both. Just played with one in the GMC lot to confirm this.
Not that weak highs or shutter cutoff really matters much anyway when you have roof level LED spots mounted on the sports bar......you not only see the deer, you give them a sunburn.
People who drive on the street with LED light bars turned on should be tied to a chair in front of their vehicles and forced to look straight into the light. Those things are like staring into the sun for oncoming traffic.
They don't drive far in Canada. The first cop you go by will pull you over and fine you.
That's why it's a good idea to hook them to your brights--it's never an issue for oncoming traffic.
They don't drive far in Canada. The first cop you go buy will pull you over and fine you.
No, you want them on an independent switch, or a remote switch, for off road use to assure they are never accidentally on with any other vehicle lighting.
And no cop ever bothered me because State law states that they are street legal so long as they are equipped with opaque covers when on public roads.
The Ontario provincial police are ruthless. Any accessory light that is turned on except fog lights they will most likely come after your. This includes any LED lights the kids like, undercarriage lighting is a big no no..
In fact they pull more cars off the road then mechanic's. You do not see big rust bucket running around or damage vehicles. They pull them over do the same this as they would for lights road side safety inspection and hit you with a compliance fine. You are required to correct the issue they deem unsafe.
I personally dont think the the 16 slt LED light output is as bad as you guys are making it out to be. I did the conversion on my 14 Sierra and compared to my wife 16 Grand Cherokee/HID the SLT led lights are way brighter. Here's a night pic:
Problem is not having off road lighting, it's failure to cover them when not off road and on public streets.......thankfully over here the police here are bright enough to distinguish the difference.
And there are certainly times when they are necessary, I want to make damn sure of what I'm aiming at!
No problem for me, I don't live or plan to travel in Canada.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • I have a 2025 GMC Canyon Denali.   On a trip recently the engine failed.  The dealership diagnosed a bent valve and says there is a service bulletin that indicates to 'relace the engine'.  The truck only has about 14K miles and is under warranty.   The failure occurred 5/11/2026.   So far I have worked with GM Customer Assistance and Roadside Assistance.  Evidently no engines are available and nobody will offer a date when a new one will be.   Coming up on two months with no repair or timeline and no loaner from the dealership.   GMC Customer Assistance is 'ghosting' me and keeps closing the cases I've opened with no resolution.   Hoping someone can help me on how to escalate this issue.
