I have a 2016 Silverado 1500 I've been trying to locate a squeak noise. Dealership told me it's my leaf springs but it only happens when I give it throttle. Anyone have any sort of advice. When listening to pin point it comes from all sides!! It's getting on my nerves badly!
Have you had a friend with you to try and pin point the sound location? I had someone help me yesterday pin point a different issue and it was very helpful. Have them either inside or outside the truck. In my instance they were under the truck with the E brake on as I lightly pressed the gas and they were able to pin point the issue.
My father was in the truck with me radio down windows open and we both heard it on our own sides of the vehicle. Possibly coming from the center?
Put your trip meter screen up; at the bottom right you'll see it says V4 or V8.
As you apply throttle; if you hear the squeek happen and see the icon switch from V4 to V8 then that means it's the exhaust flapper. If so you can clamp the flapper open to confirm the noise has stopped.
I'll try that in the morning!! Thanks for the opinions and advice
Well, do you have the infamous V4 to V8 exuast flapper squeek or is it something else?
From the looks of things yes I do I changed my screen to see if it followed v4 to v8 and lo and behold it does lmao
Well, that's luckily that's easy to fix. In my opinion just clamp it open; if you go to the dealer they may replace your catback but that doesn't mean that will fix it; at least in my case when they replaced my catback on my 2015 the squeek went away but a louder more annoying rattling replaced the squeek. That's why I recommend just clamping it open; just my opinion.
http://sandyblogs.com/techlink/?p=3296
http://www.gm-trucks.com/forums/topic/153020-exhaust-adaptive
They told me it was dirt getting inside my leaf springs. But ehhh next time I'll go for my annual oil change I'm going to tell them it's not my suspension. Possibly in due time I'll change out the exhaust for something where I can tell the truck is running at a red light.
These trucks have problems with the leaf spring bushings squeaking too. But based on what you found I would say your noise is definitely the Passive Exhaust Valve. Just show the dealership the TechLink that was linked above.
It doesn't hurt anything but is really annoying. I have been living with mine for a few months now. My dealer knows about it and will replace it whenever I give the word be he isn't sure the new valve won't start to squeak too.
Thanks for the exhaust flap "squeak" heads up. My truck just hit 80,000 kms, and almost like someone threw a switch......there's that noise. I would guess there is no code or CEL related to this? And, is this just a noise and no mechanical issue for the future? Like a few other small annoyances, I prefer to "let 'er buck"!
Was the rear springs well and spray silicone lubricant into them and see if it goes away. This is only a temporary fix but it will tell you if it is the springs.
Just had my exhaust replaced for this problem. Or you can buy the range afm disabler for $189 and you truck will stay in v8 so no squeak. If you clamp the valve open you will have a helicopter noise in v4 the flapper prevents otherwise.
Another free way to disable AFM is to shift down into manual and lock out 8th gear aka set it to 'M7' (6th gear on 6-speed transmissions, 'M5').
  • 3 years later...
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
