Mine does the same thing, I do know the 6.2 has a mechanical pump. It has a roller and runs off the cam. I'm working on the launch of the 6.2 in Spring Hill,Tn. And happened to notice it while delivering parts.
Sent from my SAMSUNG-SM-G920A using Tapatalk
The 4.3, 5.3, and 6.2 all have mechanical pumps driven by the rear of the camshaft, it puts out 2175 psi of fuel pressure.
http://www.enginelabs.com/engine-tech/is-the-gen-v-engines-combustion-system-really-new/
Had the fix done todayDrove home tonightGuess what? It didnt work at all
Really? Kool. Well I'm scheduling mine next week to go in. So we'll see if I'm lucky. My truck seems like it lacks power. I drove a GMC Sierra the other day and it felt so much better that I though it was a 6.2. Popped the hood and it was a 5.3. I was like wtf! Feels way more responsive than mine
Edited by Emjay33
  • 1 month later...
I too have had the strange sound, but mine is intermittent,(now warmer weather, happening more) and it only happens if I LOCK my doors and the truck sits over night or for several hours. On the days I have the cyclic buzz sound, my touch screen will also mess up. I might have black screens, or I will have blue screens, minus the bowtie, or it will be normal by just having mileage on dash cluster (I am not sitting in vehicle) 3x I had a door chime w/o key in ignition. Also,sometimes on days with buzz, my downhill brake assist will not work, or theft light when locked. It just spent a month at the dealership. They do not know what the "cyclic buzz" sound is, even though I told them it sounds like the fuel pump.I have recorded video of all this happening. As to the cluster, they checked all connectors according to bulletin,no issues with grounds, software current, but can't explain both and or why intermittent and connection to both. As to shutter on cold acceleration or up hill at low speed. Mine was so bad, there was times when cold I could barely get up my hill. Dealer didn't have a fix yet, no codes stored. So, I fixed it. I installed a cold air intake and removed the resonator flap before the muffler and after. I have excellent power, just a slight touch of drone on v4 @ 53mph.
I finally brought my truck into work to do the update. It fixed it on my truck.
  • 9 months later...
On 3/20/2017 at 9:56 PM, Isaac Allen said:
Figured I'd let everyone know I flashed my 2017 with ECM/TCM tuning from Blackbear Performance and the issue is completely gone. The truck also drives so much better! 100% satisfied.
I'm curious what you chose for a tune? I'm also considering the Blackbear Performance tune (if I don't ultimately decide to trade away from GM).
  • 2 years later...
It should be part of the vehicle purchasing process to explain to buyers all the sounds that the vehicle makes when you turn it off and when you open the doors.  It would help make everyone feel better after the sale and when they get home and hear all the sounds to know it is normal and not an issue.
15 hours ago, Raymond 65 said:
Is it normal for the fuel pump to come on no matter which door I open. 2020 Sierra crewcab.
Mine comes on when I unlock the truck, so... probably?
  • 1 year later...
I posted earlier questions regarding gas in oil. My 2018 Sierra fuel pump activates immediately when opening driver door so if I was to go in the truck a couple of times just to get something without starting it would the not create gas in oil…would anyone know?
Should not, it is just priming the fuel lines. Doubt if it activates after they are ready (meaning opening the door(s) multiple times).
No, the vehicle isn't running so the fuel doesn't go anywhere but to the fuel rail to build pressure so the injectors can open when called upon.  You should also notice that it doesn't run every single time if done in short order because pressure is already at the recommended setting.
    • No ETA is available for that engine at the moment in the GM system.   I would start at the dealer.  Try and talk to the parts manager or service manager and see if they can start a CX Connect case and get an ETA from GM on when engines may be available.  If they just check Parts Workbench and say "no eta", they aren't trying hard enough.  They need to do a CX Connect and chat with DPAC to find the ETA.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
