No Middle Headrest In 2nd Row
If the helmet solution is not good enough, place the wife in the middle seat.
  • Replies 70
There is a difference between the terms head rest and head restraint. I wonder how the injury risk factors compare between rear seat positions in a pickup truck. This might be worth researching. Your wife's concerns about having one child at a greater risk of injury is understandable. I personally found it was a far greater safety hazard having three pre-teen and teenage children sitting together. When my children were that age, I sold the pickup and bought a Suburban! When finances got tough, I bought a mini-van! (Aerostar!)
Does it really make a difference? These trucks are already pretty safe as it is.
Sit in the middle seat and get in an accident (no I am not wishing this upon anyone). Please report back how your head feels and if the rear window held up.
Ryan B.
She must really not want the truck. I'm shocked the lack of a center headrest is a deal breaker and she seriously feels kids are unsafe without it.
Honestly, my kids (13/15) sit center position with friends and they're all tall enough it wouldn't make a difference.
Show her some crash tests vidoes of all 3 brands - headrest is last of the concerns.
There are no crash tests that specifically test this seating position that I'm aware of. Like the OP, I have three (smaller) kids and this was an issue for me. The concern is only with getting rear ended - whoever sits in the middle will likely hit their head on the rear window fairly hard. Obviously some of you don't have kids or don't care about their safety, but some parents do.
All other OEMs have them - GM is just being freaking cheap and skipping on safety accessories. The next models better have them or I will seriously consider a different vehicle.
I only have 1 child. She will always have a headrest.
Out of interest, I googled this topic and I stumbled on Ford owners asking how to remove their rear headrests! I grew up at a time when seatbelts were not required and headrests were not found in North American vehicles. I do recall aftermarket "slip on" type headrests available at auto stores. They would be found next to the car seats that hooked over your front seats! I would be interested in hearing from others who have found a suitable solution to the OP's concern. My son drives a CC Silverado and has 3 small children. Although this is not their main family vehicle, I'm sure the occasional use may occur!
Ryan B.
The two headrests in the backseat make no difference to a full grown adult, as their heads are above them anyways
They go up and down. They can also be completely removed.
Didn't realize they were adjustable I had never bothered to look
One of mine is adjusted up for my son who is in a booster seat (required by law).
We have 3 kids and once my youngest is out of his booster I'm selling or trading in my Silverado for a Suburban or getting an F150. That headrest could save your child from a significant injury so the fact that people laugh at it being a deal breaker is not a laughing matter for a parent. i also bought seat belt tethers for my other two kids to bring the shoulder belt to the correct placement on their body. I've seen enough fatal crashes to know seatbelt safety etc is a very real thing. Good luck with your situation
    xdieselmechanic
    xdieselmechanic
  • Who's Online   2 Members, 0 Anonymous, 614 Guests (See full list)
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
