To buy a buy back or not
Found a vehicle and it was a buy back for the check engine light always coming on(I called the stealership and asked) I see on the car fax that they were replacing parts.
Something tells me most people here will say don't waste me time but I willing to listen to people's 2 cents. FYI, I'm not in a rush on a vehicle I just happen to be poking around online and this vehicle got my attention. It's a 2015
I really don't know why you made this post....do you really think anyone here is going to recommend you buy a truck that GM had to do a buy back on?
RUN FOREST RUN!!!!!!
Sure for 1/2 price, and the reason for the light. I would buy a hail damage truck first. I'm surprised they can resell a buy back.
You're also not telling the whole story. What's the asking price and how many miles on it? Was it a lease? Did you ask to see who the original owner was?
Buybacks have to be "branded" as such, not as bad a lemon law return in their eyes. as far as I know, they have to give full disclosure as what was wrong, and If the problems have been resolved.
Buy it if you like, but then don't waste people's time writing to forums posting and asking assistance for your complaints.
My bff was in the court room with a lawyer fighting GM to lemon law his silverado, and at the last second GM agreed to buy it back not as a lemon buy back, but to give him XX amount of dollars plus 3K cash on his next purchase. So it was a lemon in every sense, but was not branded as such.
kind of like what happened with my 2014. It was to be a buyback, but everyone involved drug their feet during the 5 months it took too get my 2016, so it ended being just a "trade in" with Chevrolet giving me $8000.00 towards the down payment of the 2016. Dealer was then able sell the 2014 as though nothing had ever been wrong with it.
l like the looks of the truck. Reminds me of mine.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
