Hey people, you might have stumbled across some of my other stuff in the realm of retrofits, or perhaps the main topic of this video, getting the factory heated/cooled switches to work without requiring BCM programming (AKA, Cheap). Well, I threw together a video talking about the LIN bus which is used on our trucks and the basics of how it works. Let me know if you like this and I will keep making videos talking about these subjects and as always feel free to ask questions, and it doesn't have to be about this. If you have questions about other systems on our trucks that haven't been asked before let me know and I will dig in to try and find the answers. There isn't much I am not willing to do on these things. So enjoy and forgive the part where the camera falls or where my dogs decide to play in the background! If you like this let me know and I will kick some more out in the near future!
Thanks,
Kyle
https://www.youtube.com/watch?v=28pi-P65Qwg
Looks like it cut off my title. A little Dr. Strangelove reference.
Edited by Darth_Vader
  • Like 9
I joined this forum to learn about what I can and can't do to my truck. It is guys like you that I enjoy following for the wealth of information you share!
  • Like 7
LIN Bus, MOST Bus... all new protocols for me for sure. I enjoy reading, watching and learning the stuff from this forum.
I'm also subscribed... would love to learn anything I can about the controls on my truck and how they work
2015 1500 LT Silverado Midnight Edition
good work darth, i have been working on this type of project my self, might be the cheap controller i have but so far i can only get full heat or no heat for the seats using factory switches. lol i will keep watching your post and maybe i might fiqure this out. many thx to your hard work
I'll have a video later today talking about this specifically.
@Darth_Vader - I finally watched the entire video after getting interrupted 4 times. Was there an action for me? LOL. I heard you say "Phil" and wasn't sure if that was meant for me.
If so, let me know what you need from me and would be glad to provide you the info needed.
Yep! Can you measure the resistance of the factory seat heater elements for me? No hurry or anything, just don't have any to see what kind of resistance they have.
Hey everyone, part 3 is up and we have heat! Sort of, lol, heat on my kitchen table. But that being said, I have ordered the elements for the passenger seat, if I have time next weekend I plan on tossing them in the truck and heating the stock seats up using the factory switches. At this point and time the control for the driver side heated seats are 100% complete. Once that is beaten I will start turning towards the cooled seats and possibly talking about putting out a heated seats only retrofit kit if there is interest.
https://www.youtube.com/watch?v=69FibPjjK_U
  • Like 4
@Darth_Vader - I enjoy coming back to this thread and the continued learning I get from it. Thanks! All of my work has been simply adding missing circuits to a harness [emoji51]. This is Engineering at its best. :).
Edited by pgamboa
still watching and learning, could you tell me where you got that control board
Brace yourself. You are about to get an info dump.
    • I have changed oil and filter for years by starting a cold engine to warm oil up, let it run 5-10 minutes depending on temperature. Drain until it starts dripping, refill with quantity from owners manual or get it close.
    • I changed the factory fill oil in the rear diff of my truck for the first time today and the miles is close to 9000 on the truck. There was a lot of fines on the magnet, a very thick layer but working it through my fingers it all felt like mush and as most know it appears like graphite, so no surprise chunks anyway. Certainly was time to do it from my thinking and could have been done sooner but the oil didn't look awful but sure wasn't new looking and never expected it to either. I did use some solvent to help me clean out the bottom area of the axle housing, just get any other stuff settled at the bottom washed and wiped out of the housing for the bit of effort it takes. I used Amsoil Severe Gear 75W90 in the easy packs to try out what they are like and I used up 4 packs and didn't spill much at all in the process but did take all four of the packs and go to the work bench and emptied them into a measuring container and there certainly was some in them that added up to something, then poured that into one of the easy packs and squirted in what I could get out of it. I would say the level is within 1/8th of an inch of being level with the threads at the fill plug so just the perfect amount. Once again, more than what GM says the fill volume is but computes with what others are adding to their rear diffs as well.
