After 3 years, back in a Chevy! 6.2L
Well guys, I'm back in a Chevy! After being away for 3 years, I'm back. 2014 Chevy Silverado Crew Cab 6.2L LTZ. I love this truck! It's everything I ever wanted in one, wish it was 16-17 model yeah. But I can't complain too much!
Gonna colormatch the door handles and mirror caps. Add darker tint, new wheels and maybe a black grille. Get HID's, different exhaust, and eventually a BlackBear tune. Also, I'll end up putting a leveling kit on it. And do 305/50/20s with new wheels. Something like I did on my old truck. You think that would look good guys?
I would do another lift like I did, plan to keep this one one for awhile. Wear and tear killed my other one. It's nice for looks and such. But this 6.2L i just wanna keep it simple for now. But here are the pics, including my old setup before my lift.
Opinion and suggestions are welcome, thanks!
062f63ae362757e40bd140a694e887bf.jpgd535456e3e50e7a6011cc48d1af9bfa7.jpg133f20cb746ef393ccda60197d6d2eca.jpg
5c4a9c3fedaf4d99a933d7ab00b0ad28.jpg6bb633c9d50b3a7c15a1b3dc667113c8.jpg42f55a0325faf932e694305fc592ad87.jpgc42e72808742d4f4f4a0bd7993d76f1f.jpg
Congrats. Welcome back to the club!
I just came back after almost 3 years.
Nice - What are your exhaust plans?
:chevy:
When you're ready for color matched door handles, and mirror caps, I have some. Pulled them off my 17 with 5k miles
Nice looking truck.. best advice I can give.. put money aside. 10-10 guys will do something with there truck... myself I knew exactly what I was jumping into... alot of good guys around here. Extremely helpful.. you got any ?'s just ask.
Man should have held out 1 more year for the new truck. Could have gotten that first 4 cylinder 2.7 turbo! ... If you think I'm kidding just wait.
Nice truck, miss my 6.2 all the time.
Truck looks awesome. I thought those lights were already the hids?
These are halogen lights, but HID's in 5K would look really good! Had 6K on my old truck,
How about that. I miss having a GM truck and just miss being on here a lot, actually. You gain a wealthy amount of info on here.
:chevy:
I have no idea. Probably just change the muffler out and dump it over the rear exhaust for clean look, that's what I've done on my last 2 trucks. Thinking of Flowmaster, Magnaflow or Borla.
I'm ready now, will they fit on my '14? Gloss black, right?
Thanks man, this site is very helpful. Probably the best one on the web, imo.
Long time no see bud, welcome back! Where in VA are you located?
Thanks bud! Over here in SWVA, not too far away from Bristol, VA.
[emoji1417][emoji1417][emoji1417][emoji1417][emoji1417][emoji1417][emoji1417]
Welcome back to GM. Just over the mountain from you near Boone, NC. Nice truck. Hope she treats you right.
Welcome back. I like your comment about keeping it simple on this truck. I think the stock wheels and stance on your '14 look good. I'd consider a +1 on the tire size and maybe a 1.5" front level but keep the rest stock.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
