I just had the back seats and carpet out to install dynamat. I have the power slider it looks complicated back there. I would plan on 3 hours just to tear everything apart and put it back together unless you are used to working with interior trim. Plus whatever time it takes to do the window. You might as well do some sound proofing while you got it all ripped out.
I love my slider. The borla exhaust sounds better with the back window open.
Pic is what it looks like under padding of rear wall. Looks like some sort of power supply in the middle and wires that go up to the window are on passenger side. 773933ddbfcf0f19a1062790c972ea7a.jpg
I like the idea of sound proofing. Do you have a thread and more info to help me out?
Also I like Toyota's back window . I like my but it would be nice if the whole window went door. But living in Florida the A/C is on 95 % of the time.
Some good info on page 3 of this thread. Probably a few other threads out there. It's multilayer process with lots of acronyms to confuse you. http://www.gm-trucks.com/forums/index.php?/topic/199845-GM-Borla-Arrives-Today---Cold-Feet
Ok so if you don't have an LTZ or SLT you will need a whole new body harness; which will run about $1000 CAD.
It could be expensive but this would then allow a lot of other options to be wired in, like power passenger seating and heated seating.
I was considering doing the entire body hardness swap but I don't think I would have the time and also would then end up adding even more lol
But since I can grab the whole rear assembly for very very cheap I may just buy the overhead console plastic and switch for it.
I was told I can simply run 12v to it and it should work as it doesn't run to bcm(no programming required).
So could I do this with the factory switch?
I have plans to put in black cloth on days off so I will be tearing seats out anyways, I now may sound proof entire body and do this mod while I'm at it. Long as I can confirm running a simply 12v to switch then to motor on the window will work. So if someone could help me here, I'll make a nice write up.
Ok so I'm getting the complete rear assembly for just $50 CAD now.
I was quoted just $150 CAD to take my one piece out then install this one from an auto glass place.
Then when I'm putting black cloth seats on, I'll run the 12v supply. Which I'm still hoping someone could confirm.
I do like it - not much road noise from it when open - good air flow by just cracking another window with it open.... One of those options you don't realize how much you will use it until you have it........ Like a back-up camera - talk about taking hooking up a trailer to a whole other level!
Edited by Krusty
While I can't confirm the 12v, I will say the truck doesn't seem to know the window is there which may indicate it is a simple 12v source to it. For example when you hold down the unlock button for 5 sec and all the windows go down, the rear slider stays closed. My old Honda truck would beep at you if you left the slider open, the silverado does not. My guess is it's 12v power but can't confirm. Mine has the slider on a z71 which was an option, came with adjustable foot pedals (another great option)
When you take out the rear seats there are two small 10mm screws that hold the two seats together, they are easy to miss.
Hey guys - just a quick note... if you use @pgamboa , this will send me a notification.
I haven't really delved into this but based on reading @dbeto54 's thread, and seeing it can be done with power, open/close relays, and also looking at the schematic, I don't see any connections going through the BCM. My initial thought is that this can be done.
Here is a snap shot of the schematic. Looks like some circuits go between the X51L and X51R fuse block and through the X61A Junction Block. When I don't see circuits go through the BCM, that's usually a good sign.
Unfortunately for this, there is no harness that I could produce for this to make this all work. This would be similar to the auto dim rear view mirror upgrade where you would have to source the terminals for each connector, land everything, and hope it just works.
Edited by pgamboa
So what I see is I can simply run 12v to the switch, then run two wires back to window; one going to up and one going to down?
Would this make it work correctly?
I'll have the window in two days so I could post photos of connector on it. I'm hoping if I can do this, it will function off of overhead switch(instead of an aftermarket one).
Edited by WesternSilverado
I've mentioned this in the past.. but when ordering my truck I didn't want the power slider.. but being a ltz I had to have it... first thing I did was find some window place and ask for a straight swap and install for free.. alot of places turned me down.. then I found a place really close to me said yes come in asap.. long story short.. I have a solid back windo2 like I wanted and it didn't cost me a dime.
If it were me, I'd be exploring the X51L/X51R Fuse Panels and seeing what's there. I'd be looking up terminal part #s and ordering those. There is also a Junction in the X61A Junction Box. So I would want to retrofit exactly like the drawing shows and hope it works.
I like a sliding rear window but it is very low on my priority list when looking for a truck! It does help get the hot air out quickly when starting out on a summer day! The window place that traded you probably knows how to wire these as an aftermarket item.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
