G80 locking differential
All higher trims have it. (LT with Z71, all LTZ and HC)
Available on the rest.
if it is included that makes sense that I don't see it as an option, but when I look at the full spec list I don't see it listed on there which is why I was looking for the option
I believe U R well beyond the 2017 ordering deadline........ But good deals 2 B found for one off the lot........
Standard on
LT (2LT), LTZ and High Country and available on all others and Included with (NHT) Max Trailering Package, (PDA) Texas Edition, (PDU) All Star Edition or (Z82) Trailering Package.
Back in the day almost every 2wd GM pickup came standard with a g80. It's included with any trailering package or can be added on the side. IIRC, its around a $430 option.
Well worth it....or have a reputable shop install an aftermarket differential that's stronger and has better street lockup
G80 is okay, doesn't always lock up for me as quickly as I would like. If I keep the truck long term I might explore aftermarket options, I think I'd prefer a LSD for my needs and driving habits over a locker.
IMO, Better off to get the truck without the G80 and install a TrueTrac. G80's work ok sometimes, but they can leave ya hanging. They also can explode, which ends your day instantly. It's a neat design on paper, but horrible for real life in varied conditions.
I've owned 3 G80's now.
1998 S10 Zr2
2007 Silveraldo LT3
2017 Sierra SLT
The ZR2 and the Silverado had 100,000 miles on them and the takeup in the diff was a bit sloppy. Ive had the Zr2 wheels up with one rear tire in traction and it pulled me through.
The one in my new truck works great, better than the old ones. The interesting difference is the addition of traction control. I wonder if traction control will help the G80's live a bit longer in snowy, icy climates.
It's a good option to have and well worth the extra money! If you were to add it later it'll cost big bucks. Check out the different Packages, it came with the All Star package on my truck!
It also came with my Sierra sle value package. That's a nice package. Even already had a spay in liner. Hope to get a camper soon so that controller with come in handy.
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
