rough idle at stop
Is it normal to have a 'very' rough idle at a stop (in drive foot on brake), its much worse with the A/C on....If I shift into park it smoothens out.
2016 Sierra Crew All Terrain 5.3l
thanks.
Jim
Probably too new for the typical throttle body cleaning issues. Take it in
Sent from my SM-G930P using Tapatalk
Have engine mounts settled or replaced. There's a bulletin for this or a PI rather. But GM is aware. Go by your local dealer.
Thanks for the replies.
Yes I have been to the dealer once on the issue they said could not duplicate but it is doing it increasingly now so shouldn't be an issue the second time in but have a feeling they may say it's normal so building up some info and ammo for the second time in to the dealer.
Thanks.
jim
my 2016 had something similar, wasn't too rough but wasn't normal, it happened after i installed the airaid mit. i cleaned my MAF, and tightened up a couple loose clamps and it went away.
  • 3 months later...
How did you clean your MAF? Also, which clamps are you referring to?
Sent from my LG-H932 using Tapatalk
Mine is subtle enough for me to notice it, my passenger also noticed it and said it shouldn't be rough like that.  My truck only has 16k miles, 2016, owned it almost 2 yrs now.  If it acts up again, I might have to get it in.
  • 6 months later...
thx again, It kinda went away in the winter cold weather but back now in warmer weather it seams....
  • 1 month later...
   They could not duplicate the problem huh? ... How much did they charge you, to do absolutely nothing? I'm guessing $125 after tax?
  • 1 year later...
Did anyone figure out the problem, I have a 2017 Silverado 64000 miles it also has a shake/vibration hesitation when I’m on a red light or stopped on while having gear on D  , no problem when I change gear to P or N or reverse . P/N/R gears Rpm is steady on the 500’s once I change to gear D rpm drops under 500 . I took it to dealer they said they drove it and couldn't duplicate it so frustrating .
Have you guys checked your spark plug wires to make sure they are on there? Use dielectric grease while you pull them out.
Back driver one was almost unplugged on mine before, i thinks its sort of common for them to get loose.
Anytime there is a rough idle, its good practice to check the plugs and wires.
