Strength of tailgate?
I hear ya. I always thought that way on the old trucks--have seen a lot of them WAY overloaded in oilfield and agriculture usage, beat on year after year with little to no maintenance. But on these new thin metal/plastic/aluminum trucks, well lets just say that some of the parts tend to bend or break a lot easier than they used to. Best wishes
Body parts yes, frames and drivetrains though have gotten stronger and more robust. I would put a new drivetrain up against an old one any day and it will come out on top in terms of toughness and longevity.
Tyler
The strength of this Silverado tailgate compared to my 2nd Gen Dodge is night and day...I sat 2000 pounds on that Dodge tailgate without a hint of stress, this Silverado's tailgate flexes with my 275 pounds on it...
I wouldn't put that much faith in a modern dodge. Our company truck is a 2012 ram 2500. The tailgate is so bent up it doesn't latch properly. I treat my truck with equal abuse and no sign of tailgate issues.
Mine is flat...I've laid a straight edge across it for layout.
You dont have cable slack ?
Mine has slack in the cables until I put weight on it
Nope, cables are taught when open...I can watch the area around the cable attachments flex when I walk on the gate.
I'm actually surprised I haven't ripped one or both of those off yet...
Sent from my SM-T350 using Tapatalk
Look at the gm bed closely when you open it, it's not level with the bed. It's definitely designed to flex until it's level. Probably makes it tougher as well, almost the same effect as using a pillow to absorb an impact
I don't think the tailgate can flex that much without buckling. The cables are tight on each corner and the center of the gate would need to bend over 1" to make it "level". I have done a lot of measuring and investigating, see the link I posted earlier.
Your prifile says you drive a 2012. From the checking i've done- all the trucks from 2014+ have this stupid raised gate. If you lay a long board in the truck, it is over 1" in the air over the crack between the bed and gate. again, See the photos in my other post, linked in post #2 in this thread.
The tailgate on my 2017 does seem stronger than the one on my 2013. If I stood or sat on the 2013 gate, I could hear the tailgate handle bezel pop, probably due to flexing. I would have to snap the one corner back in place. The 2017 gate with the same or more weight has not made any wierd noises.
Tyler
Yep. Old days=hell for stout bodies/beds and weak small blocks. We had a couple of Chevy one-ton dually flatbeds with gin poles out in the oilfield in the early 80's with 350 4bbls and 4 speed manuals. Amazing how much we hauled and towed with those things. Everybody fought over who got to drive the '78 one with a 454 and 4.11 gears in it. Now a smaller V6 has more power than those old trucks did. Today, we have strong motors and pop-can bodies and beds. There ought to be some kind of happy medium. My truck got waves in the tops of the bed rails when it was new, when a couple of light ladies sat on them to watch 4th of July fireworks--I couldn't frakkin believe it. I hope the new frames are tough--they should be--the trucks weigh about 1000 lbs more than they used to, and that's with aluminum engines.
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
