Does anyone have difficulty with the auto fold mirrors?  I just got a 2017 denali ultimate.  I have turned on the mirror autofold setting in the settings menu.  However, it does the task unreliably at best.  I have set it to off then back to on a few times but it usually does not work.
Is there a trick or do I need a dealer visit?
Mine works great 100% of the time. You holding down the lock button on the fob?
Sent from my SM-N910V using Tapatalk
I am not.  I am just turningoff the vehicle then hitting the lock button once as a fast press.... so I need to hold it?
Yes you need to hold down the lock button to fold the mirrors in
You have to hold the lock button down to get them to autofold.  And hold the unlock button down to get them to auto unfold.  Just like the memory seats, which now require you to hold the button down for them too.
this is one of the things I think is kinda weird on our trucks.  Auto folding mirrors aren't actually "auto".  You do have to hold the lock button as others have said.  Not what I'd call "auto".  A buddy of mine actually just hits the folding button on the door as he turns his truck off.  Such a habit for him that he doesn't even think about it anymore. When I saw that a couple months ago, before I got my truck, I thought the truck was doing it automatically.
For us lower trim trucks (LT/SLE and lower) we don’t have that option. So with the help of @alexantics supplying me the after market fold module, this function Is true “Auto Folding”
GM calling them "auto-folding" is a misnomer. I was confused at first too, trying to figure out how they "auto-fold." Whether it's when you shut the ignition off or shift to park or what. Turns out you have to cycle the "auto" mirrors either with the button on the drivers door or with the key fob. :sigh:
I think we have different ways to use the term automatic.  If you use a definition like "(of a device or process) working by itself with little or no direct human control."   then pushing a button to fold or unfold your mirrors is truly automatic.  Your transmission is referred to as automatic even though you have to shift it into gear.  Maybe "remote" would be a better way to describe folding mirrors with a key fob.  I think it would be annoying and unnecessary  to have my mirrors fold with the opening and closing of my door.  I seldom park in a manner where I would need to fold my mirrors and my manual mirrors fold effortlessly on such occasions.
It's a nice feature. I use it out of habit every time I park. The process has become "automatic".
I was confused when I first got my 2015 too. My old truck, a 2007 Silverado NNBS had auto-fold mirrors, and when on, you just had to put it in park, and they fold. Never had to push anything on the fob. For the longest time, I thought mine were broke when they wouldn't auto-fold. Didn't know you now had to push a button to do it.
Yeah dude you gotta hold it a couple secs
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
