Ac started to blow warm air. Took to shop had it recharged and still blowing warm. Tech said he thinks it’s the compressor and i should take it to the dealer.  Any suggestions?
1. go to a different shop.  they should be able to tell if the compressor is working properly or not.
2. there should be 1 or 2 temp. doors that control the temp each side of the cab gets.  See if all the vents get warm air or if it's just on one side, and if the temp will vary with the controls (with the engine hot).
3. find someone with a more advanced code reader, that can read codes from all the computers on your truck.
This model truck has two major flaws in the cooling system. One being the condenser and the other is the high pressure lines cracking in the bends. I got lucky *knocks on wood* and had the hoses replaced along with a bracket under warranty when mine started blowing hot in July. If your is the condenser, well, get in line. This part was still on a national back order as of a month and a half ago. Fixed on your dime too if your warranty is out......Thanks GM.
Is it seriously still on backorder? I thought they got all of that situated back in October. I know it was a 30 day wait list back in the middle of the summer so I would imagine it's better now considering most people aren't using their AC.
Sent from my LG-H932 using Tapatalk
That info came from someone I do business with that said he was waiting on the back ordered part. I assumed he was being honest and never followed up.
Nice profile picture... Pew pew
Had mine changed last week, dealer stock, service writer didnt know about the issue when i droped off, when i picked it up same afternoon, he knew 2 in a row with failed condenser
Edgar
Sent from my SM-G935V using Tapatalk
good to know that Gm has finally caught up on production of these as summer is right around the corner.
If your truck has around 40k miles on it, it might benefit you to just order one and sit on it. [emoji3]
Mine went out earlier this year and I had about 65k on my truck at the time. I had the dealer fix it and they covered like 75% of the cost. I paid about $500 out of pocket. The condenser itself from GM was like $320 I believe and then plus the seals was like another $100 bucks or so.
I attempted to get the condenser from O'reilly's however they also did not have any and were on back order... crappy situation but it cost me an extra like 100 - 200 bucks to have GM do it as me doing it myself.
un-luckily for me I took out my cracked condenser and took it to orielly to get a new one before I knew about all this non-sense. So I had to put in the old condenser back in. So I did all the work for no damn reason...
Why did they not cover it under warranty?
Because I was almost 30k miles out of bumper to bumper warranty. They covered a decent portion which was better than nothing. Should they have paid for the whole thing, sure. But they definitely did not have to pay a cent either so I'll take it.
I gotchya. I just dropped the truck off at the dealership for this issue today. We'll see what they come back with.
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
    • Well I ordered the Autel ts508, and it won't work on my truck I tried all the 2023 and everything it just says vehicle not supported lol   I'm able to send this unit back, so I'm going to do that, then I'll just stop into a some tire shops and if none of them are able to do it, I guess ill have to spend a bunch of money to get a good scanner..... Thanks GM lol
    • Don't need the air tube but that's how everyone sells them. Most places won't remove that one piece and sell it alone. No money to be made. Hoping someone swapped theirs out for a CAI and no longer wants it. Not asking anyone to give it away. Offering to buy it but I don't need the tube. It's held on by a hex head screw and nut. Been all over eBay.
    • Wait, you guys are changing your oil???
    • If you need that mount looking piece.  You need the air tube.       Cheapest one I see on eBay - 2007-2014 GM Silverado 1500 Air Cleaner Outlet Duct Assembly 5.3L OEM 15901934 | eBay     Same price but free shipping - 2009-2014 CADILLAC ESCALADE 6.2L AIR CLEANER OUTLET DUCT ASSEMBLY 15901934 OEM | eBay
