Best All Terrain Tire?
On 2/14/2018 at 2:10 PM, amxguy1970 said:
This other thread you started asks the same question, did you not get an answer in there or what is the point of another thread? There won't be one answer, just do your research and pick what you feel is the best based off of what you read and find...
Tyler
I thought of OP's earlier thread while delivering meals to shut-ins after a recent snowstorm.  My Michelin Defenders took me through rural icy roads up long unplowed, untraveled gravel driveways winding through hilly acreages.  I drove effortlessly through conditions many  A/T tire buyers won't ever experience.  OP wants to replace his Defenders because of a poor experience on a sports field.  I suspect replacing tires may not give him the improved performance he desires.  A good AT may give the appearance he's after which in itself is a good reason to look for new tires.  Switching out tires is expensive so I choose a good performing all-purpose tire.  My truck looks like a grandpa truck and I have four grandchildren who will agree!
  • Replies 30
Congrats on being a grandpa, you’ve done good. About the tires, It’s not an expense thing with me just want something great in all terrain but mostly pavement. I bought the Defenders because logically I drive mostly on pavement but that one experience on the sports field with just wet grass makes me worry about any future pulling a TT on camping trip possibly on wet areas. I’ve got a buddy that swears he’ll never by another Michelin Tire, bad experience with dry rotting and horrible wear, thinks they’re junk and charge more cause of all the commercials they make. It’s kinda like you pay more at a fancy restaurant than you would at another for same quality because of presentation.
Thanks!  Getting old has its ups and downs, but the option to aging is far less desirable.   I've heard and experienced the dry rot issue.  In 2001 I inherited my father's pristine 1990 Cadillac.  I had to replace his Michelins with 35k kms and 12 years of being on the car. I learned at that time that Michelin's may rot before they wear out.  They do have a 6 year warranty and their compounds have evolved.  The cost factor favors Michelin for me.  Costco's point system,  installation charge, Michelin's semi-annual sale,  and convenience offset the higher cost.  My current Defenders replaced my oem Bridgestones.  They look similar but the traction on slippery roads is noticeable.  In '09 I replaced my oem Firestone  AT's with Michelins and '00 replaced my oem tires with Michelins.
You may find a brand that is more visually appealing but I personally believe you currently own the right tire for your type of use.
My friend has E load KO2's on his '16 Midnight WT. They are at 15% life in less than 55,000km (34,000m). Just something to consider. He said not a chance he will go back with a BFG. He is going with a set of Amp Terrain Grippers. I am pretty sure they are a Chinese tire. I have Pro Comps on my summer truck, they are garbage do not buy them.
Unfortunately, you will not know what is the best AT tire for your application until you try one or more.  There are many good AT tires on the market, and they each bring something special to the party.  I am partial to KO2's, but I have also had very good luck with Firestone Destination AT's on a 1500 I had before my current 2500.  Lots of folks seem to like the Hankook Dynapro AT tires.  It all depends on what you are wanting from a tire.    Mine have to deal with a couple of miles of gravel road any time I leave the house, off road taking care of things on the property, upper Midwest snow belt stuff, and lots of mud when things thaw out in the spring.   Looks are about the last thing on my mind.  My pickup stays dirty more than it does clean, so I am not trying to impress anyone with how pretty and off road wanna be my pickup is..  I just want to get thru the messes I need to get thru and also a tire that rides well on pavement  including excellent cornering and braking and being on the quiet side.  The KO2's do that for me.  Significantly better than the stock Michelin LTX AT's that came with the pickup from the factory.
When I was researching tires, premature wear was one thing I read several times about the KO2s. It seemed that they either last forever or wear out before you make it home from the tire shop. I'm sure at least some of these cases has to do with incorrect tire pressures. Some people just fill them up to what the sidewall says, but 80 psi is WAY too much for a half ton running around empty. I'm not saying this is what wore his out, cause I have no idea.
My factory General Grabbers still had 40% tread when I got the KO2s at about 57k miles. I cut the sidewall on one of the Generals driving places a 2wd truck with highway tires shouldn't be, so that's why I replaced them. With about 10k on the BFGs, they have absolutely zero wear. It's not a lot of miles yet, so I shall see how they wear over time. Through the mud, rain, sleet, snow, and hail, these tires are yet to disappoint.
My falken wildpeak at3w are doing pretty good. I have over 33k and the tread still looks deep. They ride nice but I think they may be starting to make noise while driving down the highway. Other than this i like these tires a lot and will recommend to others.
I just put these tires on my truck. I only have about 400 miles on them, so I can't comment much. But they are much better than the Continentals that came with the truck when dealing with the snow and ice here in the northeast. They look cool too.
Too little air, they run them the same as the door sticker for their P-Metrics and they wear quickly.  I learned this the hard way.  Started running mine at 30 psi and on into the upper 30s and after 6k miles I'd lost 2/32 of tread and at that rate they would not last 40k miles.  Stubbornly, I kept slowly airing them up to 50 psi which is what BFG recommended and even in the mid-upper 40s the wear stopped.  In the last 4K miles, they've worn about .5/32, if that much, all around.  1500s don't need much more than 50 psi when running LTs according to the door stickers.  The new Silverados can be shod with C-Ply KO2s as an option.  Another couple thousand miles and it'll be due for a rotation and balance and will check the tread depth again.
That's just it, too much or too little. If you go off the sidewall, the tread will be gone before you know it. The door sticker gets blown out the window when you switch to an LT tire; pressures that low still cause wear and heat up the sidewall, as LT tires need higher pressure to support the thicker sidewalls. I run mine around 45-50, unless I'm hauling heavy or towing, then I pump them up a little bit.
Right.  After doing some learnin', I calculated that at 42 psi, the tires would support the maximum weight of the rear axle.  So I ran them all at that for a time.  Still a little too much wear, checking often with the tread depth gauge.  Mileage wasn't all that great either.  Then saw a 2500 Yukon's door sticker and factory said to run them 50 psi in the front and 60 psi in the rear.  Well, 50 psi is max for my C-ply and 50 is what BFG kept telling me to use so that's what I eventually wound up with.  When cold they are all over the place, from 45 to 51, starting off in the morning they vibrate some until they get up to temp and then settle down.  On long trips the side facing the sun is always a few pounds more than the other!
I never noticed how sensitive the big tires are to the sun/heat.  One side is usually lower than the other in the morning and afternoon if the truck sits in the driveway all day.  So when I want to check I have to do so at first light!  Goodness, I miss the days before TPMS, then I didn't know these things happened with tires and it wouldn't bother me now like it does!
The nice thing is, I got a load pressure chart off of BFG for the KO2's I have.  I inflate to the recommended pressure based on the actual axle load.  For my 2500, that would be between 50 and 60 psi in the front, and between 45 and 70 psi in the rear.   I don't like just guessing what pressure should be run or basing it on anecdotal ideas.   The tire folks put a lot of R&D into their tires and they probably have the best idea on how much air should be run in them.
Now one thing I learned, if you tell the tire maker what vehicle the tires are on, they will punt back to the vehicle OEM for recommended pressure.  They like to pass the buck on liability.   But if you tell them the tire you have and the size only, they will email you a load pressure chart on the tire so you can run the best pressure in the tires based on weight on them.
Thanks everyone! I think I’ll just stick with the new Defenders that I just had put on my truck.
Michelin Defenders. I have a small farm in Southern and I can pretty much go anywhere on my farm. I used to have the KOs but they are horrible in the rain.
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
