strobe my Factory DRL’s
I have a 2016 GMC sierra 3500 HD I am looking to strobe my  factory LED DRL’s because there is no where to put hidways in the Housings and I seen it on YouTube video a guy posted up so I can be done but not sure how plus The DRL Strobing is bad ass So if anybody’s going to imput or has done this before let me know
dang, Anthony beat me to it. I also got a speed turtle 2.0.
I wanted to have some more visible lights when plowing snow near the county hwy. You can configure exactly which lights you want to flash, its a pretty cool little toy.
I also like how you can use the wired in switch, or remove the cord and turn it on with a double-tap of the truck's cargo light button. IE, no wires, drilling, etc.
It works on every GM truck for the last 10 years. Are you sure it doesn't work on '17s or have they just not updated the website? I'd suggest confirming with an e-mail. they were helpful when I asked a question prior to ordering mine.
When I messaged them a month ago they said early 2018 for more applications. Then put me on a call/email list if they offer it for the 2017 2500/3500 platforms.
Wow, I'm surprised they haven't updated it yet for trucks that are over 1 year old. It is early 2018 now, so it could be any time then.
I'm just thinking the trucks haven't changed much since 2016 so it may already work anyway. But I don't know anyone with a 17 to test it out.
It picks up all the chicks :rolleyes:
Tyler
thanks for the info but I Seen that already but I dont know if I like it cuz It more like a wig wag then a strobe I want it more like this but the owner said it to difficult to explain in email cuz he is in  Chicago and im in Rhode island
  • 1 month later...
anybody use the speed turtle and have a trailer hooked up? do the trailer lights also flash?
I did not plug in trailer, but confirmed with multimeter that the pins for the trailer wiring are getting intermittent signal for the brake lights and reverse lights.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
