Sadly I fear we'll eventually reach a point where there will no longer be V8s in trucks, but rather turbocharged 4s and 6s.  And there will be nothing we can do about it.  Other than not buying them.
When it comes to trucks and towing and working, torque is more important than HP.  High HP numbers are great for racing and sports cars, but torque is what gets the job done.
As hard as it is, I have decided to not put down the little turbo 4 until I get the chance to test drive it to decide for myself.
:thumbs:
Cite all the data you want, there is no replacement for displacement... Turbo charged v6's in trucks don't seem like a good recipe for long term durability...
I will argue that point wholely.
1) how does NA vs Turbo handle atmosphere?
NA) by losing 3% every 1,000 ft
Turbo) keeps same Max HP. Turbos spin faster in the less dense air keeping the intake pressure at the same level. This is the same concept used in turbo-prop/turbofans used in planes and helicopters.
2) how does NA vs Turbo handle changing engine loads
NA) it can only create negative pressure in the manifold for lower demands. The displacement stays the same, AFM ignored (which is why GM uses it, but parasitic losses)
Turbo) by using a smaller engine and a compressor, most the time the engine manifold pressure is positive. By increasing pressure, a smaller engine can actually move MORE air than an NA engine 2x it's size. More air + more fuel = more power
So why all this talk of turbo now when the small block V8 has been king? Well simple... Computers. Better modeling, better programming, better engine computers, better understanding of the physics.
Did you know that the first year of F1 moving to the newest set of turbos, tire manufacturers had problems? Yeah, coming out of the turns, the turbos spooled via an electric motor essentially acting as a procharger (on intake and exhaust mind you). The stresses were too much and teams had to dial down the new systems to avoid killing off their tires.
Sent from my XT1585 using Tapatalk
Since HP is simply a mathematical number based on torque and rpm it would make complete sense that the HP is higher when the torque is also higher at a set rpm. With the torque line the way it is, who cares about the hp number.
This gas engine is undersquare.  Been a long time since we had an undersquare gas engine in a car or truck.  That explains the low redline.  Running what I think is going to be the first "living" camshaft gives the high flat torque line.  Can't really call it a torque curve now.  By essentially giving the engine a unique camshaft profile for each and every rpm is something that has been dreamt about. If they can control lift and duration, as well as cam timing, you can have optimal valve action instantly.  If this engine gives a good life, I can see it removing the 5.3 from the lineup.  A pickup running tp 60mph in under 7 seconds, doubt a 6.2 can do that now, and for sure a 5.3 can't.
Wonder if they will come up with an undersquare inline 6 with the same camshaft technology and make that an optional engine?
On 5/22/2018 at 6:39 PM, Daly said:
but full-size trucks should have v8's IMO.
I'll just leave this here......
Hardest working pickup engine out there.
Some think that since trucks have come with v8s since the 30s that it must be the best engine.  As long as GM has done the proper real life stress testing on this new engine it may very well be a major advancement.  They aren't revving the snot out of it, it may surprise a lot of skeptics.
And to my point earlier... NA V8's suck in the mountains. That is when you need the most power anyway. A force fed engine is much better.
Also, everyone knows that they do make NA diesels, right... They are even worse than NA gas engines on paper, but cheaper to manufacture.
I'm not talking about diesel's, but nice try. I'll gladly take the 3.0 duramax in the 1500. But in gas form, IMO, it's a V8.
Edited by Daly
Please, someone get the I4, tune it and to an axle pull with a V8 so we can put this to rest.
And to prove what? That a modified 4 Cyl can be as good as a stock V8?
The 2.7 EB will humiliate and small block and any LT.  The 3.5 EB crushes the LT 6.2.  The new GM GTDI 2.7 will sell like crazy, and should have an excellent tow rating.  It will also outshine any V8, especially when it comes to passing a gas station.
I don't see how the egoboost crushes the 6.2. I've never had one able to hang with me yet. As for the 2.7 it's just downright silly when they line up and think they have something cool. One of my favorite things to do is dust the blue kool-aid drinking crowd who listens to Fords oral crap.
The 6.2 is good for mid 5 second 0-60 mph runs stock. Not arguing, just thought you may have had a typo there.
I've actually run as low as 5.1 seconds and that's with 33" tires. ( And a tune)
Just how many of the yet to be released 2.7 4cyl trucks have you had "line up and think their cool"?
    • I have changed oil and filter for years by starting a cold engine to warm oil up, let it run 5-10 minutes depending on temperature. Drain until it starts dripping, refill with quantity from owners manual or get it close.
    • I changed the factory fill oil in the rear diff of my truck for the first time today and the miles is close to 9000 on the truck. There was a lot of fines on the magnet, a very thick layer but working it through my fingers it all felt like mush and as most know it appears like graphite, so no surprise chunks anyway. Certainly was time to do it from my thinking and could have been done sooner but the oil didn't look awful but sure wasn't new looking and never expected it to either. I did use some solvent to help me clean out the bottom area of the axle housing, just get any other stuff settled at the bottom washed and wiped out of the housing for the bit of effort it takes. I used Amsoil Severe Gear 75W90 in the easy packs to try out what they are like and I used up 4 packs and didn't spill much at all in the process but did take all four of the packs and go to the work bench and emptied them into a measuring container and there certainly was some in them that added up to something, then poured that into one of the easy packs and squirted in what I could get out of it. I would say the level is within 1/8th of an inch of being level with the threads at the fill plug so just the perfect amount. Once again, more than what GM says the fill volume is but computes with what others are adding to their rear diffs as well.
