58 minutes ago, starman8tdc said:
Do you know if your engine has direct injection or port injection? If its direct injection, then the install time would be a bit longer, but still - the bill is extremely high. Your right, the dealership charges a lot. I'm glad to hear that you didn't have to pay for it.
It is direct injection
57 minutes ago, cpttimerestraint said:
$1,800 is the going price by the time you get 8 injectors, all the extra seals and gaskets required and the labor to really it all apart.
Sent from my Moto G (5) Plus using Tapatalk
But you have r&r injectors twice. Plus diag twice.
So we picked up the car on Friday.
I was told that the fuel injectors they installed was bad out of the box. All the talk about carbon on cylinders and blah blah blah was just that imo.
They “said” they replaced the 2 injectors they just replaced..... I find that hard to believe but.... we drove the car home and the light didn’t come on or spit or sputter at this point.
On 7/10/2018 at 2:24 PM, YJSONLY said:
Sooo I stopped by today because I had to get something out of the car. No call just showed up.
Talked to the mechanic myself.... said they have test for leak down test and it all checked out.
Says that it is having a miss but not sending a code for a miss. Only a fuel trim code showing.
Had to dig around. Found that the number 7 plug was gapped/smashed due to carbon build up on top of the cylinder. Said he put new plug in. Ran vehicle and they same code. When pulled new plug was back to close gapping. Said that need top of cylinders needed cleaned of carbon.
Sorry dude but the spark plug gap doesn't get "smashed" from carbon build up. If spark plug gap is truly "smashed" you have a mechanical failure of some sort. I am not buying that explanation.
Like I said I think they screwed up something when installing new injectors. Ie bad seal, o ring or gasket....
So I really drove it myself today vs my wife. And at idle in park the rpm gauge is not consistent. Varies about a solid needle width. This normal?
I would pull the plug on that particular dealer. I think a fresh set of eyes on the problem is warranted at this point. Maybe another Chevy dealer tech has seen this problem before?
And more money out of my pocket to boot tooo. Might come down to that tho. This isn’t a small dealer either.
Sometimes the smaller dealers are way better.
Ha. The other small dealer I took it to. Didn’t even have a tech.... yes a Chevy dealer that had zero techs.
On 7/12/2018 at 10:59 PM, starman8tdc said:
    4.6 hours? WOW! I have never seen any injectors that were not easily accessible. Learn something every day. Any chance you could upload some pics or repair instructions?
    As for the more expensive injectors, I would not go that route - but that's just me. I have had good luck with the cheap injectors on many rigs.
If you haven't done a direct injection repair yet I suggest you watch some videos on it or take a small class. The pressures of the systems are very high, it's important to bleed off the system before you start working on it (pressures can reach 2,000 psi during operation). The high pressure fuel pump is very expensive, so be careful not to damage it when you remove it. And the injectors are high voltage (if I remember correctly) and they are probably a pain to remove because they are in the cylinder and head...I'm trying to imagine how bad it'd be to remove with over 100,000 miles on them. Yikes.
Very few systems use BOTH the direct and port injection together, although that may change with all the carbon issues on the valves, but that is expensive for manufacturers (and they care more about profit than reliability).
Honestly I haven't heard about many problems with the actual systems themselves, more with the carbon buildup on valves than anything else. I used to own a direct injected Lexus...178,000 miles and not one single issue. In fact I've seen cars with 300,000 without issue.
pretty surprised to hear the GM injectors failing at low mileage....even more surprised it's  not covered under warranty. These systems aren't exactly "new" anymore, every car on the road uses them now.
   Good info, thanks for posting.
   From what I have read, the direct injections systems are definitely superior to all the predecessors. I have been working on various cars for decades, but I have not had any issues come up with that particular fuel system.
   I will definitely study the system well before taking one apart.
    • Hello All!   My 2019 Colorado 3.6 LT, 4WD Crew Cab has approximately 77,500 miles and I recently began experiencing the well-known transmission shudder between about 30 and 65 mph. The problem had worsened to the point that I could no longer attribute it to road conditions - and I had decided to bring the truck to the dealer - when recently, I experienced a sudden loss of power while driving at maybe 40 MPH. Several warning lights flashed, the “Check Stabilitrack” message appeared, and the Check Engine, Stabilitrack, and Traction Control icons remained illuminated. The truck regained driving power, but it stayed in a low gear with unusually high RPMs for the speed. (limp mode?) Because I was only about two miles from home, driving slowly, I was able to make it back and run an OBD-II scan, which showed fault codes U0101, P0700, and U0100. My next trip in the truck was to drive it to the dealer the following day. That trip began normally, but after about a mile I experienced another loss of power, along with the same warning lights and the same “Check Stabilitrack” message. As before the truck remained driveable, but again operated at an abnormally high RPM-to-speed ratio and seemed stuck in a single gear. About a mile later, the dashboard lit up once more, this time displaying “Check 4WD.” Soon after that, I arrived at the dealer. I have verified that the truck still has its original factory transmission fluid, which means it has never received the corrective fluid exchange outlined in GM Technical Service Bulletin #18-NA-355.  That was Thursday of last week and I've heard nothing yet from the dealer.    According to Technical Service Bulletin #18-NA-355 and the build date of my truck, my truck should have the newer LV fluid. I've done a little research and read something about a problem with the wiring harness as well.   Anyone have an insights into this situation?  Thank you!!
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
    • Having codes and an engine light with no hints on what might be causing it is nothing short of frustrating. How long have these concerns been present? We want to know more so we can look into ways we might be able to help you. When you get the chance, please fill out our support form with additional details on your experience so far. A member of our team will follow up with you as soon as next available: https://s.gmc.com/support-request
    • Knowing the life of your brakes is a highly important status to keep track of. If you suspect your brake sensors need attention, please fill out our support form with additional details on your experience. When did you last take it in for inspection? Our team will follow up with next steps as soon as next available. Please include your username and GM Trucks Forum in the form as well. Support Form: https://s.chevy.com/support-request
