Getting (free)1st Oil Change today at the Stealership. Oil life Remaining 67% with 2500 miles but wanted to get it done before the summer driving trips down the beach.
Sent from my SM-N960F using Tapatalk
Had it paint corrected and ceramic coated at Taurus Auto Detailing in Austin. The guys there are amazing! They did my PPF also.eba65a57784be67676c5fb7b5a1c2af9.jpg8f4389f8c7c46d98855998fa776b0dae.jpg
Tried posting this this past weekend.
This past weekend I finally removed the air dam and de-badged the "Custom" from the tailgate.  What a difference both make in the looks.  Wish I had done it sooner.
Added paint match door molding and black AT4 emblems.
What rims do you have? Those look sharp
Sent from my Pixel 2 XL using Tapatalk
Installed the EGR slimline visors... Easy and it looks great.
17 hours ago, Jav_eee said:
To my understanding the highs won’t stay on with the fogs with just the auto fogs Mod. I want fogs to automatically come on when I leave my low beams set to “auto” and I also want them to stay on when I activate my high beams.
Those look awesome. I may just have a to grab a set! Do they affect visibility at all? I know some of them come all the way down to the mirrors
No viability issues, the front ones do come down all the way to the mirror but it's super minimalistic at the mirror. I chose these because there are a lot of folks here that talked about how easy they were to put on, and they are.
So use one of the diodes they sold you and connect it to the park lamps/fogs. This gives you what you’re looking for.
Are those in channel?
Yup.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,185 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
