I have a 2020 AT4 HD with 250miles on it and my screen froze yesterday. Completely unresponsive. Pulled over and turned the truck off two or three times on my hour drive home. Didn't work at all. Hoping its fixed when I leave the house today.
On 10/5/2018 at 9:50 AM, 1997_GSX said:
Still a bunch of crap buy a 60k truck and they can’t finely tune something that is used every day. Does anyone else have a rattle coming from in the cab back in the rear when going over bumps? I have yet to take the time to figure out what that is
I know this sounds super dumb, but lift the rear seat and see if there is anything loose rolling around in the storage area. When I first got mine, every time I went over the railroad tracks near my home I was hearing a dull thumping sound from the rear of the cab. I found my jack and the tools provided weren't strapped down.
  • 1 month later...
On 10/6/2019 at 6:28 PM, cozzy said:
the only way to get sound out of my 2019 is the change the radio station when the no sound thing happens
I have noticed this too.  Changing stations up and down brings sound back.
I have a very similar problem where if the truck is turned on and it was previously on a Sirius radio channel, sound will play for about 10 seconds and then stop.  I have to change channels for the sound to come back otherwise it never does.  It does *not* happen with FM radio, only if the truck starts on a Sirius station.
I took it to dealer and they replaced the radio inside the dash and it still does it.  There is a new software update out and my truck is updating right now.  Fingers crossed...
My radio went completely dead as soon as i got it home from the dealer. About 1.2 kilometers (about 3/4 mile).  Turned around and went back. They disconnected the battery for a few minutes to reset it.  Radio started to spike the volume randomly for a second or two several times over the last month and a half.  Now the radio froze and then went completely dead on the weekend.  The dealer had a mobile crew come in to look at it today and they will be replacing the radio.
  • 3 weeks later...
  • 3 weeks later...
On 10/2/2019 at 5:19 PM, Wendy Smith Legro said:
2019 Sierra and just hit 4K for mileage. Lost all sound out of the speakers? No radio, phone, nothing. Real sad for a brand new truck. Suggestions?
Same here.  5000 miles. Radio complete blank. Has frozen in past. Fix this @GMCustomerService!!
Getting the cable between the radio and the touchscreen replaced today to see if this resolves my issues with the blank screen/touchscreen not working.
My radio is being replaced Wednesday.  4 weeks to get the radio and i'm not the only one.
Edited by CNADN SIERRA
I have a 2019 Custom and have ahd it about 7 months. I have had several serious issues with the readio/ herad unit like some of the other guys. Ihave already had it replaced under warranty Once**- but it keeps having the same issues:
1. Unit shuts down  while im driving down the road.
2. Head Unit freezes and becomes locked out while playing music/ driving down the road.
3. wont open Carplay/recognize the phone- does same thing in bluetooth mode*
4. Stops playing in Car play mode/ and freezes out that icon, but everything else works*- Chevy told me to take a video of the issue while driving down the road...WTF.
Has anyone had any success with radio problems ? Mine has been blacking out and freezing since 70 km.The dealership says they cannot repair without updated software and it is not released for the base radio yet.Any solutions would be greatly appreciated.
Glad everyone is keeping this updated. I was going to ask my dealer about it tomorrow when I take my truck in for the recalls but I'd rather not have them throwing parts at it if there's not a fix.
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 491 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
