16 hours ago, DougFL said:
How is the Ride with those Rims?
So far so good.  Even passed the wife's "will this mess up your truck" test.
First street truck I've seen on here...Looks great!
I've thought about doing a street truck with low profile tires. The last LP vehicle I had I constantly worried about denting rims and spent most of my time looking for pot holes. The LP look, in my opinion, is great but its too stressful...Hope you have good luck and no bent rims... Definitely a great looking truck!
Edited by Chris walker
12 hours ago, codyaxm said:
What size tire are you running ?
I am running 275/65/20
Thanks.  I've had a few LP cars but this is the first truck.  The 305/35 tires give it a little more cushion around the wheels edges so I'm hoping for the best.
You should definitely be proud of how the truck turned out...That truck is going to turn heads! In my opinion its pretty much perfect for a street truck. The visual of the wheel/tire size combination is spot on...
Now you need to supercharge it to take it to the next level..
Are those 24s? Sharp truck.
On ‎10‎/‎17‎/‎2018 at 5:37 PM, TXGREEK said:
Had the BFG KO2’s and switched them out a day later due to vibrations at high speeds which apparently the new KO2’s have been known to have. Nitto Ridge Grapplers are heavy tires, rougher riding than OEM P rated for sure but do have a smooth ride to them on a nice road as well. Excellent traction in dirt, sand, grass, dry roads and rain. I’m running mine at 32psi. Absolutely ZERO regrets!
Sent from above
How are they for noise?
The Nitto Ridge Grapplers.  My Nitto Trail Grappler M/T are just too damn noisy.
Considering their aggressive look and excellent off-road capabilities, they’re very quite. I was running the KO2’s before the Nitto Ridge Grapplers and the Ridge Grapplers are actually quieter, much quieter than the KO2’s. I’m constantly getting compliments on them.
Recent pics
86191550a96a51c0e61bb5cc2047cf0e.jpg07c20b549fc3bbceb44ced5eedb56c32.jpg292e2a38fe791cdec87131ddddb1fd5f.jpg
Recent pics
Looks awesome!  Thanks!
Thanks man.  I'm hoping to find a 2" rear drop shackle to level it out.  Whipple SC coming after the warranty lol
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,243 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
