7 minutes ago, smpldezine said:
Color? Tire size? Leveled? Looks awesome!!
Thank you.
Shadow Gray Metallic
275/65/20 Nitto
2inch front level
I wouldn’t touch that truck. The stock wheels look much better but some of course would disagree. Personally leveled mine out and added some 33 Nittos and love it. I also wouldn’t debadge, that being said I’m almost 50 years old so maybe that’s the old man in me but that’s one of the things I liked about the truck. Congrats...
HEY! 50 is not old!
Just picked up my new AT4 yesterday, and am in heaven.  Most amazing truck I have been in.  Replaced a 2012 Sierra SLT.  Any thoughts on BAK revolver cover?
That is the funniest looking AT4 I have seen to date. After-all, it drives sideways! :lol:
Just teasing RLCC. Sharp looking Sierra you have there. Congrats and enjoy!
Beautiful truck! My At4 turned a month old this week. Amazing vehicle. Rides great. More often than not somebody asks me about it or comments when I park it. As for covers my two cents: had a revolver on my ‘16 F150. Loved it at first but two major issues: once it gets really cold forget rolling it especially with snow on it. It also takes up more bed space than I thought and made it tough for my ATV. Went to a Bakflip F1. Good cover but ridiculously heavy. Put an MX4 on my new Sierra and love it. Much lighter. No issue with tailgate and thus far seems a bit more waterproof
On 12/21/2018 at 10:24 PM, DTB said:
Fresh pics from my 2019 trailboss on a beautiful January afternoon in Michigan!
  • Like 10
On 12/23/2018 at 11:26 PM, Shawnr487 said:
Picked it up Saturday. Took it out hunting on Sunday!
Did you remove the badging yourself? If so, how easily did it remove? Any hints?
26 minutes ago, mbr2ooo said:
2019 Silverado LTZ with GM 22" Denali wheels.
Looks Awesome!
It's as easy as a hair dryer or heat gun and some fishing string, take you time and you should have both sides done within 15 minutes. A little "GooGone" or WD-40 will help take any residue that is left being with no damage to the paint.
  • Thanks 1
I asked the dealer to do it for me. Done when I picked it up. Otherwise I have done like Drew mentioned on past vehicles and had no issues.
  • Thanks 1
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
