My new Trailboss in Satin Steel.
Sweet! Best color out there IMO. Will be my next color
Yeah, this is what I'm leaning towards as well. ??
On ‎1‎/‎18‎/‎2019 at 12:49 PM, OnTheReel said:
Blizzard coming this afternoon, probably the last time the truck will be this clean until spring...
 9F610647-FE90-4A1E-8426-E7546BDFA28F_zps
22F3FD58-7794-4837-8F9A-EB7C0564CC3B_zps
1DB9A9D2-EEAA-42D4-ABDD-03B1A87A9C74_zps
Buy a cheap daily driver and keep her parked in the garage  :thumbs:
That's what I do during winter months.
  • Like 3
I've had her less than a week and now just picked her up from getting the windows tinted. Every.Single.Window. :) IMG_1536.thumb.jpeg.703411e9f77824ff086a6abbab34d559.jpeg
  • Like 6
On 1/10/2019 at 10:07 PM, Erod_66 said:
Pacific Blue with the CTX ceramic tint. So far no issues and love the truck.
That's a great looking truck.   I havent seen that color in person yet.   What antenna are you using?   How is it compared too the stock?   I would like to get rid of the tall stock antenna on my new AT4 but not sure what to get.   I tried a very short antenna (I forget which brand.. ) on my 2016 Sierra and it got terrible reception so I switched back to the stock antenna on it.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
