On ‎12‎/‎31‎/‎2018 at 7:41 AM, TXGREEK said:
HEY! 50 is not old!
Yes it is, we already discussed this.....
51 minutes ago, UGADawgs said:
They are not revos. They look like the RH:
You are correct they are RH. I have the AT4 and have the Bridgestone Duelers AT. I hope this helps.
IMG_7171.thumb.jpeg.0b33635f37ae145a097c551a876c1b28.jpegIMG_7174.thumb.jpeg.4ab9c05f2aeff876b7a2971085cc6370.jpeg
On ‎11‎/‎29‎/‎2018 at 1:35 PM, Denali Dad said:
Picked up my 19 Denali last month and have been loving it since.  Here's a few pics...
Best looking 19 I have seen so far. If I were in the market, you would have a twin truck on the west coast.
  • Like 5
Thanks man.  I'm still in the honeymoon stage, going on 3 months now!
On 1/22/2019 at 11:49 AM, Trailboss75 said:
My new Trailboss in Satin Steel.
I really like the color and the trail boss features! Man I wish they offered the TB with the 6.2l.. I have a 2016 LTZ with the 6.2 and I don't want any other power plant but that......
Edited by Threerun
  • Like 3
My Trail Boss did great this weekend in Up North Michigan.  Lots of snow and no issues at all.  Love this truck!
  • Like 7
Looks like I'm not the only one that had the idea to vinyl the hood! Really makes the lines pop. I was going for the ZR1/ZL1 look with the carbon fiber wrap and emblems. Who can spot my F-up with those? Realized it about an hour after I stuck them on after looking at some paperwork..
  • Like 8
Should be L87?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
