2 hours ago, Joedert said:
Should be L87?
Yep.. Forgot the RPO changed with the second Gen 6.2. That was about a $100 mistake. Oh well, I doubt most people don't go around with a vast knowledge of '19 RPO codes. I'll get some correct ones made whenever I have to replace that vinyl. It was a bit of a pain and I'll undoubtedly destroy it taking the emblems off. They look great though otherwise, got them from emblempros.
10 hours ago, RJVB3 said:
Looks like I'm not the only one that had the idea to vinyl the hood! Really makes the lines pop. I was going for the ZR1/ZL1 look with the carbon fiber wrap and emblems. Who can spot my F-up with those? Realized it about an hour after I stuck them on after looking at some paperwork..
I like the red hooks. I was wondering how that would look on an LTZ. Might have to do that.
Cleaned mine up today. Thus far have had tints on front two windows and windshield. AMP steps and the Bak MX4.
  • Like 6
Yep, I vinyl wrapped the hood back in October for the same reason.  Wanted that ZL1/Z06 look on my Trail Boss.  Yours looks great too!  Gives it a very unique look that's sure to turn heads.
Edited by z1boss
Thanks for representing the 18’s till you get your new badges! Good looking truck!!!
Edited by JimCost2014
On 1/16/2019 at 9:29 PM, RyanbabZ71 said:
Nice truck, still can’t stand the chrome window trim or door handles emoji22.png
Ryan B.
Chrome looks outstanding. I wish there was more...
I want a at4 in white has anyone bought one and done the wheel well molding mod yet to color match, and i gotta look and see if theres a thread but are they knocking any money off yet
3 minutes ago, TH3JUICEMAN said:
Where is it rubbing at?
It WAS rubbing. I removed the brackets behind the rear of the fenderwells. And cut the mudflap/fenderwell.  It doesn’t look perfect but it’s fine for now.  Here are some pics
    • Are you playing Slide Down endlessly but your score is still low? Are you constantly crashing into obstacles as the game speed increases? Don't worry, this article will share 5 invaluable tips to help you master the race and impress your friends. Golden Rules 1. Look one step further. The mistake of 90% of new players is only staring at their character. The secret of experts is to look towards the top of the screen (where the slide is about to appear). This gives your brain an extra 0.5 - 1 second to process the situation and determine the direction of movement before the obstacle approaches. 2. Use gentle movements; don't swipe too hard. Slide Down is very sensitive. Moving your finger too forcefully or with excessive amplitude will cause your character to be thrown off course or crash into a wall. Practise moving your finger with small, decisive, and precise movements. 3. Don't be greedy for gold in dangerous locations. Gold coins are tempting for buying skins, but life is more important. If you see a gold coin right on the edge of a cliff or next to a spike trap, ignore it. Our goal is a High Score, and your score only increases if you survive. 4. Make the most of Power-ups. During the slide, you'll encounter items like Magnets (attract gold) or Shields (temporary invincibility). Never miss them! Especially the Shield, it's your "get out of jail free card" to help you get through those deadly fast sections. 5. Stay calm when speed peaks. When your score exceeds 500 or 1000, the game speed will be very fast. At this point, don't try to think logically; let your natural reflexes work. Take deep breaths and don't panic. Apply these 5 tips to your next game, and your leaderboard will surely improve dramatically. Good luck climbing the Slide Down leaderboard!
    • If you use compressed air regularly, one problem you cannot ignore is moisture. Water in the air line can cause rust, unstable air pressure, poor tool performance, and even damage to sensitive equipment. That is why I highly recommend using a desiccant air dryer. A desiccant air dryer is designed to remove moisture from compressed air by using drying materials such as activated alumina or molecular sieve. Compared with basic water separators, it can achieve much lower dew points, making it especially useful for applications that require dry and stable air. For workshops, painting systems, pneumatic tools, CNC machines, laser cutting equipment, and industrial production lines, a desiccant air dryer can make a big difference. It helps protect equipment, improve air quality, reduce maintenance costs, and extend the service life of the whole compressed air system. Another advantage is reliability. Many desiccant air dryers are built for continuous operation and can maintain stable drying performance even in demanding environments. For users who care about long-term efficiency and equipment protection, this is a smart investment. When choosing a desiccant air dryer, I suggest paying attention to air flow capacity, working pressure, dew point performance, regeneration method, and maintenance requirements. A good model should match your compressor system and actual air consumption. Overall, if moisture is causing problems in your compressed air system, a desiccant air dryer is definitely worth considering. It is practical, efficient, and highly useful for anyone who needs clean, dry, and reliable compressed air.
    • My brand new 2007 Silverado's wax frame was rust from end to end partway through it's SECOND winter here in MA. That stuff is completely useless.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
