Is it just me, or is there no where near the stock suspension rake that there was on the previous model?
my last truck was a 2017 Sierra and the lower front rake was extremely noticeable, with this truck it almost looks dead nuts even.
mine is an RST, does that change the suspension height front or rear from any other trims? I haven’t noticed except realizing it doesn’t look like it has a rake like my ‘17 did.
I just bought cheap 285/45/22 all seasons for cost at the moment, but want to swap to larger AT or MT tires at some point, looks like I could fit considerably more tire in front and rear without any suspension mods?
Edited by Brown324
Add info
A spacer clears the caliper but now the bad thing is your truck isn't hub centric anymore and is now lug centric.  Gm trucks don't like to be lug centric.  The max spacer thickness that can be used is 3mm (1/8") to remain hub centric.  There's only one place I know that makes a 3mm spacers for these trucks.
I don’t care to have spacers to begin with, that’s why they are sold. Currently installing the new setup. I will post pics when done
No, your suspension is not different with the RST.
The rake on my RST Z71 with 20's is barely noticeable. It's much less than the K2s, for sure.
New setup on. And I love it
Black Rhino Roku 17x9.5 +12 offset
315/70/17 BFG ko2
Very minimal rub, barely touches the back mud flap on the inner side
I’m on a 2 inch ready lift level
  • Like 4
Added 1.5 Motofab level, 1 1/2" wheel spacers. Stock tires going today for 285/60r20 Toyo R/T's
Edited by anthony2558
edit photos
  • Like 5
What brand spacers you get
Got YitaMotor off amazon. Normally i purchase Bora, but wasnt sure 1 1/2" would work, and didnt want to go threw the hassle of returning with Bora. But I have to say that this brand I got off Amazon seems to be just as good.
https://www.amazon.com/gp/product/B07C9ZFB4H/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Note: I did not have to cut any studs for these to work. These stock wheels are notched in the back so any stud that pokes out after the spacer has a place to go.
Any noticeable vibrations at highway speeds?
None. I drive 35 mins every day at an average speed of 65-70mph and have no vibrations to report.
Care to send a link to where you got em from
Look 3 posts up from yours.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
