You bought a truck to match your dog! And they both look great! Congrats.
Sent from my SM-N950U using Tapatalk
  • Haha 1
Moend-
How is the squat with that load? What’s the estimated tongue weight? Do you have air bags or using a weight distributing hitch?
Edited by Race Neely
6 hours ago, Race Neely said:
Moend-
It does not squat so bad if loaded properly I would say 3-4 inches give or take. Don't have air bags or weight distribution hitch but thinking to trash the rancho shocks for better ones. The 5.3 work really hard going up hill it can do it but I have to wring it neck to keep up the pace. I try to keep it 10-15% tongue weight. Overall truck does really good but if you do this often or travel far I would go 3/4 ton. These half tons can handle a lot every once in a while.
Cheers!
Bought her June 29th. I am just so happy with this girl. My 07 has 270k miles and still doing well but, this '19 is just flat out amazing. Drives like no other.
  • Like 3
Just picked up my 2019 Sierra SLT. Love this truck so far. Drove my 2013 Silverado ls for 6 years and this truck is leaps and bounds ahead of it!  Still sad to see her go though!
  • Like 4
Took my 2019 LT Trail Boss beach cruising on the Outer Banks, NC. So much fun.
  • Like 7
Nice truck!  I like that red color!
Thanks! It’s our company colour so we’ve been buying it for 20+ years!
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,357 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
