38 minutes ago, Snuff said:
I love the brown interior - so glad I ordered what I wanted?
Sure looks Gray to me.
They call it dark atmosphere on their website. The dash and doors are brown and the seats are a lighter brown/gray. Definitely not a plain light gray like others I have seen. Have you looked at one?
Edited by Snuff
No I haven't, I'm not doubting you, it sounds nice it's just the picture looks gray to me. I'll have to go see if I can find one on the dealers lot, not as if I'm replacing mine anytime soon though.
Thanks! Go check it out - I think you will like it. For the Texas Heat it is better than black.
Agreed on this.
These new leather seats absorb heat and retain it really strongly. If you do not have ventilated leather seats, and your seats are in the sun... prepare to have a warm backside as you drive. No matter how well you cool the interior.
Even when my leather RST is in the shade, the ambient 100º heat in TX warms the seat so much that it just will not cool down. :(
2019 Sierra 1500 4x4 SLT X31. Picked her up yesterday. My first GM truck!
Edited by lastr002
  • Like 10
Just now, lastr002 said:
2019 Sierra 1500 4x4 X31. Picked her up yesterday. My first GM truck!
That’s a fine looking truck!
Welcome to the forum. Very nice truck! The deep blue goes very nicely with the chrome!
You're correct; the seats are gray.  I have the same interior (Very Dark Atmosphere/Gideon) in my RST and love the color.  My dealer had many Silverado's in stock with the Dark Atmosphere/Gideon interior.  The dash, doors and console are a very dark brown, the console leather padding and door armrest is a silver tan but the seats are gray as you perceive them and have no brown in them.  My previous Sierra had the Cocoa/Dune interior.  The dash and doors were more brown than the Dark Atmosphere and the seats were a beige/tan.
Congratulations and welcome! I hope you enjoy the new ride! It is a beauty ?
10 hours ago, Moend said:
Sometimes I wish I would have gotten the 6.2. Maybe next time ?
How does the 5.3/8 handle that load? And probably the better question, how does the 1/2 ton do stopping that load?
Actually stoping is not an issue at all the trailer break controller on this truck is very impressive. Taking off on an incline is a kind of slow. It is very stable tho. This load max out my capacity.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
