2019 Trail Boss...Why no 6.2L
  • Replies 72
Trail Boss is suppose to be available with a 6.2 at a later date.
For now you have to opt for the Sierra AT4 ( Trail Boss in GMC Clothing) to get the 6.2
My 15 5.3 truck drove like a good ole truck. It ran and drove just fine.  However my 18 6.2 truck drives better, more nimble and lighter feeling, not as cumbersome, actually fun to drive. .  Unfortunately if you want a better than average driving Chevy/GMC you have to spend a lot of money and/or get an overly blinged truck.  Unfortunately my ultimate 19 would be Custom Trail Boss with a 6.2.  And unfortunately with the prices of the ‘19s looking like they do, I could probably get a Ford Raptor for the same money as a 6.2 GM.  Or maybe settle for a non blinged Ford with a turbo 3.5 or the 395hp 5.0.  That’s too bad because I’ve always had GM trucks.
If you’re looking for performance and don’t need a p/u, just about any performance car would be cheaper. The money you save buy a used pickup. That’s what I did.
5 hours ago, Jaywroe said:
Just as the title suggests....why no 6.2L on the trail boss?
I LOVE the look of the Trailboss vs the Sierra AT4 but want the 6.2L
What gives?
I think it was a trade off with GMC as the LT trim gets the diesel and the Sierra SLE does not.
1 hour ago, chevy2tuff2006 said:
Its a unicorn motor.....Gm wants to say they have the most powerful V8 in its segment but doesn't allow anyone to own one who doesn't have deeeeep pockets.....
This is no longer the case as the limited f150 gets the HO 3.5. With 450/510
i agree though give the people an option
"most powerful V8". Then Ram says "Most powerful standard V8".
It's all a game.
6.2 should be available in RST and Trail Boss at a minimum.  You can get a center console in the LT either.
6.2 is a money maker.  How much more does it cost to make?  GM makes $2500 Everytime they sell it, but between the 6.2 over the 5.3, 10 speed and few other things, it's probably 2000 pure profit.
It’s not all about motor it depends on what you’re using your ride for. I agree the 6.2 should be available across the board. The right gear would make up for a smaller motor and fuel comes into the equation. If I was looking for a performance truck I wouldn’t even consider the 6.2 in the current offerings. I probably wouldn’t stay with this brand. If I was going to tow diesel would be my choice.
Here is my understanding why no 6.2 across the board.  Has to do with CAFE.  GM makes the Corvette and Camaro, two gas users per say.  Now if they offered the 6.2 in every truck and SUV then their CAFE numbers would go down per manufacture.  Not enough smaller vehicles being sold/used like the Cruze and such to counter the CAFE numbers so they don't offer the 6.2 in every vehicle. It is all about meeting CAFE numbers as whole company.  Again that is my understanding.
The funny thing about that is it seems in real world driving that the 6.2 gets better fuel mileage than the 5.3.
I still wish there was a regular cab option with a 6.2.
My 18 6.2 gets better mileage than my 15 5.3.  Both were ccsb 4x4.  Same lift and tires on both.  Both LTZs.  5.3 had 3.42s and 6 speed.  6.2 has 3.23s and 8 speed.
    • I know when I was looking around last year to see if someone handled Amsoil gear oil to buy at the retail level which of course means full price. I found an independent shop that works a lot on GM/Duramax pickups and they did not bring in the 75W-85 as they just stuck to the 75W-90 for the front and rear as a standard practice for the HD trucks which makes sense anyway for the higher hp/torque diesel and pulling heavy loads in four wheel drive. I haven't changed my diff oils yet but still plan on using the 75W-85 for the front diff as I highly doubt I will be beating on the truck and figured for my use type the bit thinner oil would be to my benefit for the winter for that slightly less drag. Very different weather here all winter vs northern Washington near the coast, that's for sure.
    • Ok that confirms the extra quart theme they are still going with which must mean they have noted some initial use more so then some engines and probably the bigger factor in all of this probably isn't the engine so much as its the insane distance or OLM that lulls a lot of the driving public into driving their new vehicle off the lot and not even doing one short interval oil change because the manufacturer doesn't say different and if the dealer follows that logic as well. Selling the rarely needing to be serviced concept seems to go over well with the public that wants to get away with as little as possible for dollars spent on the vehicles maintenance and I bet there are 3.0 engines just like other vehicles out there that never have their oil checked by the owner which goes back to why they probably felt the need to add that extra quart to avoid a costly theme.    Speaking of cutting filters open, it was probably over two years ago now that a youtuber who buys vehicles to do longer term reviews and pulls a fifth wheel through the mountains of Colorado on summer trips and that becomes part of the testing. Anyway he had a GM HD with the 6.6 gas and a Ford 250 with the 7.3 gas at the same time and of no surprise the Ford had more power etc but somewhere along the way in the few thousand miles he put on the truck, he changed the oil and was seeing glitter and cut open the filter and yeah, things were not looking spectacular. The truck about that time or soon after seemed down on power compared to what it had been and then threw some engine code, I expect the cam/lifters were failing and so he brought the truck back to the dealer and made some deal to get out of it as he knew it would sit for months waiting on a new engine as they were so backlogged at the time. He kept the GM for some time after that using it exclusively until he sold it after buying his next vehicle to do a review on. Definitely the filter can tell a story when things are starting to go sideways, but it would be a sickening feeling to cut it open and be faced with an ugly mess like that and be running a magnet through the pleats and the oil on the dirty side of the filter and see all the fines sticking to the magnet.    The dealer may have some ideas based on experience as to where that coolant smell is coming from, I would imagine if they can't find it but its smelling they would put dye in it to they could give it a run cycle and use the black light to see where it pops up, if its a hose connection, water pump, rad or even a head gasket etc.
    • Good looking truck, suspensionmaxx looks like a solid option
    • Thanks for the info, im considering a leveling kit or 4" lift kit.
    • charm.li (website) has the vehicle-specific diagnostic procedure for that code, you can use to find what the cause of it is.
