The control arms where stock, just ordered ready lift leveling kit with upper control arms designed to change the geometry of the stress on the components especially the control arm and ball joints
The only modification i did on my truck was the 1" spacer. Scared the hell out of me when that tire folded and locked up !.
So that's 2 trailboss trucks that failed. It appears factory 2" plus 1" for 3" total is to much upper ball joint angle.
Beware trailboss owners with lift  blocks without upgraded upper a-arms ! .
Did you get it professionally installed, curious because I wanted to do a RC, level but now I’m second guessing... did you do an alignment after installing too?
On 10/12/2020 at 11:25 AM, ALLSTAR said:
Added a Motofab 1" spacer (CH-1LM-TB)  to my 2019 trailboss. after about 8 months passenger side upper ball joint separated.
Normal driving, couple railroad track crossings daily at speed that might have extended suspension.
Lucky i was going only about 25mph when it came apart. Going to go with better angle upper a-arms.
Was your level professionally installed? And did you do an alignment? Curious because I’m second guessing doing it now..
I installed them myself. Its just a spacer, 2 bolts, Its pretty easy to install, you really cant do it wrong.
I could post a pic when it gets light out. Went right to alignment shop and they had to do a minor adjustment.
Here is closer view of ball joint
I’m not a mechanic.  Bought my truck new off the lot as it sits today.  Can anyone look at my angles and tell me if I’m driving around a ticking time bomb?  If so I’m going to get my suspension fixed.
From my understanding is that every stock is already stretched, but still good if you keep factory settings on it. You only push it if you plan on leveling, if so the consensus seems to be to replace the arm to fix the geometry. Readylift has a kit that includes the arm.
I agree. MUSGO'S AT4 appears to be factory, and looks good to me .  Can someone with just a 1" or 1.5" level with factory upper a arms get a picture of the ball joint angle like the one Musgo posted for a comparision ?
RC’s level is 1.5in but it still apparently caused the same issue. I guess replacing the arm is the only way to fix the geometry, but I don’t know for sure. I would like to see someone’s geo with a professionally installed level, see if it’s still the same. Also some Chevy dealers preload a 1in level on their trucks off the lot. Would like to know where they get their kits
Only reason I’m concerned is the truck came with 285/65 20s.  So I was worried there was a level the dealer added to do so.
Hello I have a 2020 at4 with the 1.75” leveling kit with control arms. On these trucks they recommend control arms with a leveling kit. To keep all the angles right for the cv axel joints etc. I’ve had it in for about 2 months now. Zero problems at all, truck might even ride better. I also have the truck sitting on 22x12 -51 offset with Toyo 33x12.5
    btm
    btm
  • Who's Online   1 Member, 0 Anonymous, 1,659 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
