Hi guys has anyone dug into the radio to see if it is possible to add a front camera to the system?
Thanks for any help
I know the Chevy camaro has the option to do it with some programming I would think the system would have something especially with the over view feature
  • 6 months later...
Thanks for any help
ever find out if you could add a front camera?
  • 5 months later...
Thanks for any help
I'm waiting to see this as well.
I'm guessing this doesn't work with the T1s....  the 2019 inclusion there is for the Limited...  note it needs IO5 or IO6 radio....
I like how the linked one for the last gens has an option to automatically turn on the front camera when your going under 10mph. That's handy as heck.
14 hours ago, Josh99722 said:
Look up mvi, i added a factory dvd and overhead screen, also 360 camera.
the guy is awesome, and very helpful with any questions or problems.
i love having all the cameras!
tell him josh w/ 2016 silverado in minnesota sent you!
https://www.gm-navigation.com/shop/2014-2019-gm-360-camera-towing-system/
That's not for the new body
Bump
I do have a local shop that will install for $1400. To me that is a little too much. I am willing to spend $1000 for a factory install or $600 for a none factory install( still needs to use factory screen).
Edited by BlancoSilverado
Sorry i know its not the t1 style, I would still speak with mvi. Im sure they are working on it. Mvi keeps every retrofit oem.
search ebay for the kits. Bill craigem is a good one, email see what they have.
i would imagine ecomaster would make kits that are plug and play For the newer style.
go to a gm parts website and look through it, probably list the module harness camera in diagrams. Then find part #’s and start ordering parts.
https://www.group1autoparts.com/auto-parts/2019/chevrolet/silverado-1500/ltz-trim/5-3l-v8-gas-engine/body-cat/grille-and-components-scat/?part_number=84400532
  • 3 months later...
I have a 2019 High Country that did come with all the cameras but the front one. I am having my local dealer install it. They said it was a plug and play. Just needed to have the infotainment system programmed. It is VERY pricy but I wanted it. Just FYI. It can be done.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
