BORA is the brand name of quality bolt on adapters:
http://www.motorsport-tech.com/special/truck/chevy_s
I personally wouldn't use the Rough County brand spacers, they're lug centric, not hubcentric.  I would go with a set specifically designed for our trucks.  I think I paid $50 for my pair, which isn't cheap, but I had no vibration or balancing issues.
Mine are from RC, 2" spacers. No issues either. Have had them installed for nearly 2 years now.33fa05020c3f6707bdbe86e02b3c0309.jpg619d5f070c5ff54ddf2c09d5f50790a0.jpg
I meant the RC slip on spacers, not the bolt on adapters.
On 10/19/2018 at 9:13 AM, pewterliftedz said:
If you have the factory Snowflake wheels, you can run a 1" BORA adapter type spacer, and not have to trim your studs.  Personally I wouldn't go bigger than a 1/4" with slip on spacers, you want to make sure you're getting plenty of thread engagement.
Only a 1” spacer?  I would have guessed at least 1 1/4” or 1 1/2” would be needed. I have the factory 20” Denali Wheel which is different that the regular Snowflake wheel.  I also haven’t taken the time yet to remove a wheel and check the depth of the holes in the back.
IDK about other wheels, but the snowflake have enough relief to run a 1" adapter.
On 10/19/2018 at 11:09 AM, pewterliftedz said:
I ran a 1/4" spacer on the front of my truck when I ran factory wheels with 305s, and it helped eliminate a lot of the rub.  With a 285 or 295 I'm sure that 1/4" would get rid of all the rub.  They're nice custom hubcentric pieces, I don't need them anymore since I went aftermarket wheels and control arms, let me know if someone is interested.
I would be!  Do they still allow the oem wheel to sit on a hub ring? Or studs only?
Yup, the wheel remains hubcentric with the 1/4" spacer.  Message me if you're serious, and we can set something up.
For the record, I removed a wheel & measured the depth of the cavities in the back of my 20” Denali wheels...  a 1” spacer wouldn’t work for me.  The studs are 1 3/4” long & the depth of the cavity is only 1 5/8”.  A 1” spacer would be at least 1/8” short of what’s needed to work.  Here’s a pic of what the back of my wheels look like...   I decided to go with 1 1/4” spacers & they’re exactly what I was looking for.
Edited by steve76t
Pulled the trigger on some 1 1/4” spacers for my truck.  Install took about 1.5 hours as I was taking my time, did test fitting at each wheel, made sure everything was clean, then made sure all were installed correctly.  Here’s a pic of how she looks...
Edited by steve76t
Here’s pic down the side from front
Edited by steve76t
And one more down the side from the rear...
Edited by steve76t
I have a little experience with slip on spacers as well as thicker bolt on spacers with studs.  I ran several different sizes and styles of slip on spacers on my Camaro.  I had some cheap cast spacers for a while.  They suck.  They do not hold torque well at all.  The billet machined spacers are much better and are more stable.  Just make sure you still have enough thread engagement, minimum is 1.5 x stud diameter.  If you are short of this, ARP makes some nice longer studs.
Same goes for the bolt on spacers, billet machined are way better than cast.   Make sure they have quality studs and nuts.
"Flame suit on". I have found zero difference in performance between hub and lug centric spacers.  Not in drivability, steering shake, perceived wheel shake or bearing life.  The way I see it, the lugs MUST help center the wheel anyway with tapered (acorn) lug nuts other wise tightening them down would try to split the wheel if one or more were off center.  I think hub centric is nothing more than an assembly aid to help the lugs center up on the assembly line to speed things up.  "Flame suit off". Just my opinion.
Are your tires stock 275/55r20 size?
With a 1" spacer you need 3/4" deep pockets, correct?  I'll have to measure my wheels.  I kind of like not destroying my feet ders with rock chips though...hmmmm
No, slightly bigger with 285/55r20 which are about 3/4” taller & 1/2” wider than 275/55r20’s.  On the truck my BFGs are nearly an inch taller than the stock Goodyear SRAs it came with.
With a 1” spacer, yes you’d need a wheel with 3/4” deep pockets or more.  The other option would be to trim the end of the stud some.  There is room to do that as there’s about 1/2” of stud length that’s not threaded or used.
Edited by steve76t
    ncleg
    ncleg
  • Who's Online   5 Members, 0 Anonymous, 603 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
